lenovo yoga 300 ec and main bios dump necessary
  • gungor1981tr
    • May 2015
    • 81
    • turkey
    hi
    I would like to ask for help if you need the ec and main bios file of the device, photos of which are visible
    • 22275
    Re: lenovo yoga 300 ec and main bios dump necessary
    Originally posted by gungor1981tr
    hi
    Post the full laptop model number and Machine Type if there is one, and your bios backup .
    • gungor1981tr
      • May 2015
      • 81
      • turkey
      Model information
      • gungor1981tr
        • May 2015
        • 81
        • turkey
        I would be glad if you could help me with the bios and ec file of the device in these
        • Bonzas
          • 474
          • Indonesia
          I try build from lenovo update, but this file not include your info.
          • gungor1981tr
            • May 2015
            • 81
            • turkey
            Unfortunately, there is no image
            • gungor1981tr
              • May 2015
              • 81
              • turkey
              2 Pcs of the same device are currently available for repair, but the files have been removed from the model sticker you want
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                by haitham sharabati
                Hello engineers 😀,
                I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                💀 Problem:😅
                - Device shows “Administrator Password”...
                08-07-2025, 04:54 AM
              • robgerr
                Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
                by robgerr
                Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
                Attach...
                11-17-2023, 09:52 AM
