Samsung np300 need bios
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need a working bios on this samsung
    Board Model. BA41-02206A GBML please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Samsung np300 need bios
    Anyone please
      • 21058
      look for your bios ID with a hex editor - https://www.badcaps.net/forum/showthread.php?t=88206 .Use the forum search, there`s already plenty of bios posted for the BA41-02206A board, you just need one with the same ID https://www.badcaps.net/forum/search...rchid=25223538
      Edit: The bios version will be on a sticker on the ram slot as well .
      • String2016
        • Nov 2015
        • 2238
        • philippines
        Here is the original backup dump
          • 21058
          What is your bios ID have you found it in your backup ?
          https://www.badcaps.net/forum/attach...3&d=1598816937
          1. Open your bios dump with your hex editor of choice and search for the word SECFID ,SEC or $Revision ,
          after that is the bios version with platform ID.Example U07QAM001 QA is the platform ID
          2. After the word SECFID,SEC,SECWUP or $Revision will be the bios version and platform ID .In the picture you can see P09 (bios version) and ABE (Platform ID)
          • String2016
            • Nov 2015
            • 2238
            • philippines
            I search secfid it shows PEI P05RBF LAMPARD
              • 21058
              Look for an RBF bios, the version can be P05, 06,07,08 for example P08RBF ,look for one with clean ME firmware .
                • 21058
                P08RBF https://www.badcaps.net/forum/showthread.php?t=85336
                P08RBF https://www.badcaps.net/forum/showthread.php?t=94659
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  P05RBF BIOS need
                    • 21058
                    P05RBF BIOS need
                    P08 is newer,is there some particular reason why you need P05
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      No i just thought need same id it is ok to flash this with P08?
                        • 21058
                        Yes. P08 is only the version number,like in the thread i linked your old bios in the 1st post was P02 https://www.badcaps.net/forum/showthread.php?t=85336. RBF is the important part,its the bios ID /platform ID..
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • Kjell
                          Samsung Series 9 - BIOS issue
                          by Kjell
                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                          08-01-2025, 09:15 AM
                        • ohren
                          by ohren
                          09-08-2023, 05:24 PM
                        • C152Heavy
                          by C152Heavy
                          Summary for TL-DR readers:
                          • VCC pin (18) of PFC...
                          01-11-2023, 02:53 PM
