Samsung np300 need bios
  • String2016
    • Nov 2015
    • 2235
    • philippines
    I need a working bios on this samsung
    Board Model. BA41-02206A GBML please
  • String2016
    • Nov 2015
    • 2235
    • philippines
    Re: Samsung np300 need bios
    Anyone please
      • 20818
      look for your bios ID with a hex editor - https://www.badcaps.net/forum/showthread.php?t=88206 .Use the forum search, there`s already plenty of bios posted for the BA41-02206A board, you just need one with the same ID https://www.badcaps.net/forum/search...rchid=25223538
      Edit: The bios version will be on a sticker on the ram slot as well .
      • String2016
        • Nov 2015
        • 2235
        • philippines
        Here is the original backup dump
          • 20818
          What is your bios ID have you found it in your backup ?
          https://www.badcaps.net/forum/attach...3&d=1598816937
          1. Open your bios dump with your hex editor of choice and search for the word SECFID ,SEC or $Revision ,
          after that is the bios version with platform ID.Example U07QAM001 QA is the platform ID
          2. After the word SECFID,SEC,SECWUP or $Revision will be the bios version and platform ID .In the picture you can see P09 (bios version) and ABE (Platform ID)
          • String2016
            • Nov 2015
            • 2235
            • philippines
            I search secfid it shows PEI P05RBF LAMPARD
              • 20818
              Look for an RBF bios, the version can be P05, 06,07,08 for example P08RBF ,look for one with clean ME firmware .
                • 20818
                P08RBF https://www.badcaps.net/forum/showthread.php?t=85336
                P08RBF https://www.badcaps.net/forum/showthread.php?t=94659
                • String2016
                  • Nov 2015
                  • 2235
                  • philippines
                  P05RBF BIOS need
                    • 20818
                    P05RBF BIOS need
                    P08 is newer,is there some particular reason why you need P05
                    • String2016
                      • Nov 2015
                      • 2235
                      • philippines
                      No i just thought need same id it is ok to flash this with P08?
                        • 20818
                        Yes. P08 is only the version number,like in the thread i linked your old bios in the 1st post was P02 https://www.badcaps.net/forum/showthread.php?t=85336. RBF is the important part,its the bios ID /platform ID..
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • ohren
                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                          by ohren
                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                          The models launched in 2018 and 2019 respectively....
                          09-08-2023, 05:24 PM
                        • C152Heavy
                          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                          by C152Heavy
                          Summary for TL-DR readers:
                          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                          • Have obtained Samsung schematic & service documents - Can upload if helpful.
                          • Have read ALL applicable threads
                          • C1818 and CP820 replaced as low hanging fruit
                          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                          • VCC pin (18) of PFC...
                          01-11-2023, 02:53 PM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
