Dell G5 15 5500 bios needed
The fans spin very loudly and after 5 seconds the computer shuts down. When I turn it back on, it's the same behavior. tanks SComputers for your help -
Attached FilesLeave a comment:
hello every one
i have dell g5 15 5500
mainboard Selek mlk n18E 19753-1
Service Tag: deleted from the computer cover, and I don't know how to get it from the dump
Please clean my file, no displayLeave a comment:
Hello, please could repair my bios, the laptop turns on but with black screen, there is no video, I appreciate the help.
DELL G5
Motherboard: SELEK MLK N18E 19753-1
ServiceTag: 99TJ103
Hello guys, i hope i get the help i need here,
I had displays problems with my laptop, it's a Dell G5 15 5500, i took it to some "expert", the display is fine now, while i look at the bios setup, i have the wrong one (screenshot taken) , it shows that i have the G3 3500 with no service tag and asset tag, i guess the expert resetted it and installed another bios?
Hope my problem is well explained, can anyone help me get my laptop setup to its default configuration?
ThanksLeave a comment:
Thanks1 PhotoLeave a comment:
Thanks Sir but no post, won't auto on, fan at full speed, power indicator blinks.Leave a comment:
Hello everyone 👋
is there a way to provide the correct Service Tag from this dump files?
i think the bin on the main chip is corrupted and the Tags on the case are faded too 😢
G5 5500
selek mlk n18e 19753 1
Thanks 💙Leave a comment:
hello
model no: g3 p89f
mb code: selek mlk n18e 19753-1
service tag:42TVC63
Notebook no image keeps restarting I sent the bios backups on it
I think there is a bios problem, I need a new solid bios, please helpLeave a comment:
hello every one
Service Tag: 519P463
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
by re1nholdHello Guys
I'm currently fixing two different Dell latitudes,
I need a E5550 BIOS - SERVICE TAG is: FSFB262
So far I flashed about 6 BIOS from this forum already,
none worked,
only fan spin ~3s, LCD black, keyboard LED on/off ok,
I tried manual extraction with scripts for ages so to speak. VM is untried yet.
This laptop is not burnt, it seems to just have a corrupted BIOS.
I extra baught ram. This has to work friends.
Do you generate it this way in Windows in CMD?:
Code:E5550A24.exe /writeromfile C:\bios.fd
by Aarush653Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
Worked good before failed flash now won't power at all.
May have been a bad connection.
Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
32mb chip - 25Q256JVEN
Attach Dell Bios Update file v1.14 - original Dell update...-
- Loading...
