HP Elitebook 830 G5 Admin Bios Unlock
    commented on 's reply
    Did you read the post above.....
  • ali0robot
    replied
    hi guys,
    i have programmed hp 830 g5 32mb bios with clean bios and after flashing password removed, but after some days costumer returned laptop and laptop was like a dead laptop, all voltage was ok but laptop could not turn on, I had reprogrammed ec and main bios with good bios bin but laptop could not turn on. just power led blinking white and amber continuously.
    could some one help me.
  • hoaca388
    replied
    Originally posted by Razzpablo
    Hei! My hp 830 G5 has a bios password
    ​​​​​. I cant enter it. Can I bypass or delete it? SN 5CG8392205.
    I'm a begginer 🫣
    Post the bios file (the one with the password) and serial number here.
  • Razzpablo
    replied
    I'm a begginer 🫣
    replied
    Originally posted by Daniel López
    Hi Team!
    I am not able to backup the bios, and it has an admin bios password, i am not able to reinstall Windows, enter bios...
    The model is HP EliteBook 830 G5 SN 5CG9132LB7
    is possible to reset the pass or remove it?
    The only way to remove it is by backing up the contents of the bios chips using an SPI programmer,then posting your backups here for the pass removing, there`s currently no other way.
  • Daniel López
    replied
    Hi Team!
  • shiyab
    replied
    Originally posted by houcine4500
    hp elitebook 830 G5
    SN : 5CG9275T0H
    Produit: 2FZ83AV
    please remove PASSWORD​
    flash 16 mb ec file this unlock
  • houcine4500
    replied
    hp elitebook 830 G5
    SN : 5CG9275T0H
    Produit: 2FZ83AV
  • minhdigital
    replied
    Originally posted by JAFATAGNA
    HP EliteBook 830 G5 Base Model Notebook PC
    Série: 5CG924BXQQ
    Produit: 2FZ82AV
    please remove computrace
    after connect pc to internet show lock screen
    Send to you, First boot press F10 reset bios to factory defaults & Restart, 2nd boot reset security settings to defaults., Use BCU to fill these DMI INFO:​
  • JAFATAGNA
    replied
    Série: 5CG924BXQQ
    Produit: 2FZ82AV
    ​please remove computrace
  • peste
    replied
    Originally posted by Kostyx87
    I need to remove Bios Admin Pass for HP EliteBook 830 G5 - MB: 6050A2930901-MB-A01(A1) , i found two bios chip on the MB. One near the wifi card slot U365 and one near the KB connector U366. Wich one should i take down and flash?
    on the 16MB one...
  • Kostyx87
    replied
  • gabsi
    replied
    Thank you very much, it's perfect
  • rex98
    replied
    Originally posted by gabsi
    Please I need to delete the bios password for HP ELITEBOOK 830 G5
    ORIGINAL BIOS ATTACHED
    search here bios config utility in forum in case you don' know.
    Serial Number: 5CG940049W
    Product Number: 2FZ83AV
    CT Number: PGSLU00WBCT0C2
    Description: HP EliteBook 830 G5
    build_id: 17WWCSDT601#SABF#DABF
    Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPhKhkj4jh.DQ
    MAC Address: 00-68-EB-3C-A0-19​
  • gabsi
    replied
    Originally posted by rex98
    serial number?
    SN#5CG940049W
  • rex98
    replied
    serial number?
  • gabsi
    replied
  • KLINIK ELEKTRONIK
    replied
    Originally posted by Vesko356
    Program both SPI modules and use verification, erase the each chip before programming.
    thank VESKO365 now password clear
  • KLINIK ELEKTRONIK
    replied
    Originally posted by hoaca388
    AAA
    THANKS bios working
  • Vesko356
    replied
    Originally posted by KLINIK ELEKTRONIK
    need unlock bios
    hp elitebook 830 G5
    SN : 5CG8418QY3
    MINBOARD :6050A2930901 MB A01 (A1)
    problem bios lock
    i have try bios this tread but no luck ( manufacture unlock mode , slow display )
    i have try hp unlocker still same lock bios.
    Below I uploaded the original bios.
    Thank you for your help
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • intelg
    HP Elitedesk 800 G6 lost BIOS admin password
    by intelg
    Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
    Here is the hardware identification specs:
    HP EliteDesk 800 G6 Desktop Mini PC
    Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
    BIOS ver S21 Ver. 02.05.01 01/05/2021
    Born on date: 07/26/2021
    SN MXL11841GN
    SKU 3X8V9UCHABA
    UUID 8116E79EF6FFE94DB0B98A3188270C5C
    SYSTEM BOARD ID 8710
    SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
    11-03-2023, 02:05 AM
  • STKR123
    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
    by STKR123
    Greetings badcaps community,
    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
    I learned that desoldering...
    10-29-2024, 06:03 AM
  • macabook
    by macabook
    🧩 Initial Issue
    Yesterday, 02:17 PM
  • clrscr
    Need unlock bios hp elitebook 835 G11
    by clrscr
    please help me unlock bios password hp elitebook 835 G11
    S/N: 5CG50434RD
    thanks!...
    06-04-2025, 09:38 PM
