It worked after I installed both versions.
Thanks!
RCUnlocker
Latest Microsoft Visual C++ Redistributable Version https://learn.microsoft.com/en-us/cp...?view=msvc-170
Attached FilesLeave a comment:
I tried to unlock my HP ProBook 5330m with this tool and I got this error (in the image below)!
HP ProBook 5330m
Serial: CNF1400VLB
Product: LG723EA#ABF
What is the problem please?Attached Files1 PhotoLeave a comment:
This is a multitool and unlocker for several series of laptops. Works on Windows. No python etc installing needed, all included in package. Everything is tested by myself but since every laptop is not made equally, there might be edge cases. Always VERIFY your file after reading!!!
Unlocking
HP - ProBook, EliteBook, ZBook (including 32MB models)
Chromebooks from all various manufacturers
Apple - everything older than T2
More to come...
Information display (helps to verify file integrity)
HP - ProBook, EliteBook, ZBook (up to 16MB models for now)
Custom logo removal
Usage: Drag and drop .bin file to .exe file.
In case there are problems with unlocking your laptop, write a short description of the issue, upload original file and if possible, _unlocked.bin file aswell. Just crying for help is useless. Keep the topic as clean as possible.
You may ask for feature requests, I'll see what I can do.Leave a comment:
There is a possibility to recover from this latest disaster yes, but it will involve more work as you`ll have to fill new DMI info, thats another challenge. When you get the new chip let us know.Leave a comment:
You can choose a different 256 chip from the list or add the chip to the NeoProgrammer support list
How to add chip support to NeoProgrammer software for the CH341A Programmer https://www.badcaps.net/forum/troubl...41a-programmer
id="C84019"
page="256"
size="33554432"Leave a comment:
Sorry for the misunderstanding, is:
gigadevice 25b256dyig u9f154 aj2016
I will get this bios out and upload it as soon as possible!!! thanks!!
do you know with which program I can read it? asprogrammer 2.0, CH341A and NeoProgrammer not.... is impossible :/ how can I read it?
id="C84019"
page="256"
Here are some notes if anyone else is a novice like me:
1: For this model RCUnlocker just displayed "Unlock Success"
2: I used the GD25Q127C profile in NEO Programmer as there isn't one for the chip.
3: In NEO-Programmer I had to select all 5 options for write IC - Off-protect, Erase, Blank Check, Write, Verify. Without this selected it would not write.
do you know with which program I can read it? asprogrammer 2.0, CH341A and NeoProgrammer not.... is impossible :/ how can I read it?Leave a comment:
I have removed the bios attachment, you have already posted it twice in this thread, there is no need to post it again. There IS another chip on the board, and its 32MB, find it,look under the plastic ,look everywhere.look for SOP8 or WSON8 chips .Leave a comment:
You were asked to post both files https://www.badcaps.net/forum/troubl...31#post3546731
You have only posted the main bios, there is another chip , not sure if thats also 32MB or 16MB, but there is one somewhere on the board, maybe on the other side, when you find it post the backup.
hp probook 450 g8
Buildid:20wwr3BT601#SABE#DABE
27J69EA#ABE
BIOS: 25Q256JVEQ 3.3v
SN: 5CD0518SR5
I would like to have a clean bios or remove the password.
Thank you!!!Leave a comment:
You have only posted the main bios, there is another chip , not sure if thats also 32MB or 16MB, but there is one somewhere on the board, maybe on the other side, when you find it post the backup.Leave a comment:
I have 3 Elitedesk 800 G6 SFF PC with password locked BIOS.
Product Number (same for all 3): 8YM57AV
Serial Numbers: CZC1239T57
CZC1239T5L
CZC1239T3X
The boards are all the same revision (Cersei Rev A)
There are two chips near the BIOS markings (Images Attached):
8 pin Giga Device 25B127DSIG
16 pin 25B256DFIG
I have a programmer on order, it only has 8 pin test leads.
Can you confirm the 8 pin 25B127DSIG is the chip of interest to RCUnlocker and that the tool works with this model of computer?
Thank you.Last edited by shaggysound; 01-18-2025, 07:49 AM.Leave a comment:
Hello, I am trying to unlock an Elitebook 745 G6 with AMD cpu and dis not succeed si far. I know i missed one step may be, i dis not erase the 16mb chip before reprogramming it.
BUt i am wondering also on the quality of m'y reading because rcunlock works well on my file but doesn't display any information like model and serial number. Is that a potential issue ?
Here is attached m'y dumped file before patching.Leave a comment:
by SMDFleaJust a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
the infamous **"Endpoint Security" error message.
Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
The offsets and file sizes are part of the naming convention i`ve used for the extracted
files.
hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
filling everything after...-
Channel: BIOS Requests ONLY!
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 07:12 AM
HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or RepairThis specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-07-2024, 06:40 AM
This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-07-2024, 05:50 AM
- Loading...
