RCUnlocker
  • peste
    • 12334
    • ROMANIA
    #1001
    Originally posted by inysyl
    I am new here. I have a HP EliteBook 850 G5 with bios locked with a password and want to unlock it.
    Just trying to understand how to use this tool. What is the .bin file. How to generate that .bin file
    you need a SPI programmer..here is a video as an example..
    https://www.youtube.com/watch?v=DWWigscuQDY
    • hypermk735
      • Jan 2024
      • 10
      SMDFlea Ah great thanks so much for the script. Will try it tomorrow. Will the change in the EC bin cause any issues with the security endpoint error? I ran into that issue and wasn't sure what to change in the Main bios to fix that.
      • RethoricalCheese
        • Mar 2013
        • 1517
        • Estonia
        #1003
        You would need to replace VSS region with clean VSS or just unlock mpm. And after that, enter DMI in bios (SN, feature byte, mac address etc). This will get rid of endpoint error.
        • hypermk735
          • Jan 2024
          • 10
          SMDFlea awesome. That sounds easy enough. Would MPM be unlocked by making changes in the VSS or so where else? I noticed a region in uefitool called hp_mpm. I’m curious because I have some laptops that have wrong serial number info and uuid and I haven’t gotten a chance to use the DMIFIT because of mpm set to locked.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11379
            • Viet Nam
            #1005
            ---thumbs up
            • Friend33
              • Apr 2024
              • 22
              Hello guys!
              I've read a lot here, but unfortunately I can't get any further. Actually I only had one problem with my BIOS, then unfortunately I destroyed two contacts when unsoldering the main chip, so I haven't found a way to read it yet.
              For this reason I bought two new chips. These also work and the notebook is running again, but I have no idea how to activate MPM. Because the DMI information is incorrect and I cannot change it. When booting, the error always appears that there is a problem with the Security Device Unit.
              Since I can't get to the data from the main chip or don't know whether it's possible because of the broken contacts, I only have a backup of the original EC available. I have a backup of the new bios, but I don't know if that helps.
              I read something about this bin file that you copy onto a USB stick and boot from, but unfortunately this doesn't work. Then I read that you have to set the region to a valid one, but what exactly can I do to move forward?
              It's about an HP Elitebook 850 G5. Have already found all the data:
              Serial Number : 5CG85179YC
              Product Number : 3JX60EA
              Description : HP EliteBook 850 G5
              BID=17WWCSBT602#SABD#DABD
              3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfXgdhKhkjh.ym
              • peste
                • 12334
                • ROMANIA
                #1007
                Originally posted by Friend33
                Hello guys!
                try to write DMI data with this..
                https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.html
                • Friend33
                  • Apr 2024
                  • 22
                  Originally posted by peste
                  I've already tested this, but the setting is already set to "Lock" so I can only change the asset number. Serial numbers etc. are not taken over.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11379
                    • Viet Nam
                    #1009
                    HP EliteBook 850 G5 Notebook PC
                    • Friend33
                      • Apr 2024
                      • 22
                      I flashed the file. Unfortunately now only the fan turns on and Power and F11 light up. Only black screen and no boot.
                      However, I have to admit that before I saw your post, I tried a bios update, but that didn't change anything. I uploaded your file immediately afterwards. Is it possible that the EC chip now also needs to be reloaded?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11379
                        • Viet Nam
                        #1011
                        Here you are
                        • Friend33
                          • Apr 2024
                          • 22
                          Here you are
                          Unfortunately no real change. Power lights up. The fan turns on fully and now the button next to F12 lights up. No picture. No boot. What could be the problem? Before everything worked, only the boot error occurred and the DMI information was incorrect. Now nothing works.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11379
                            • Viet Nam
                            #1013
                            Here
                            • Friend33
                              • Apr 2024
                              • 22
                              Here
                              Fan rotates and F11 lights up. I don't understand that. The last thing I did when the laptop was still running was to update the bios to the latest version. Is it possible that some controllers aren't working with your files?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11379
                                • Viet Nam
                                #1015
                                Carefully check the bios chip area, especially the small components around the bios chip pin.
                                • Friend33
                                  • Apr 2024
                                  • 22
                                  I think my motherboard is broken. I soldered all the pins again. The notebook no longer wants to start.
                                  • ymifdal
                                    • Jan 2022
                                    • 116
                                    • Morocco
                                    #1017
                                    No longer starting just look for an unsoldered pad or a short around the IC
                                    • Friend33
                                      • Apr 2024
                                      • 22
                                      Okay, I'll check it out. Actually not much can have changed because I always read and write with a pogo probe. So at the moment the laptop starts up without a picture and only the fan is running and a lamp is on, even without RAM and SSD no beep code. I'll check it again and report back. I thank you all!
                                      • tom auguste
                                        Liquicity
                                        • Apr 2024
                                        • France
                                        #1019
                                        Hi all !
                                        This is my first post, thanks a lot for all your work.
                                        I'm trying to unlock a 840 G6 with 2 chips, a winbond W25Q128 and a MX25L256.
                                        For the moment i just dumped bin of the winbond but i've searched a lot between this thread and the HPunlocker one and it appears this model is quite recent, i have to unlock both chip in RCUnlocker ?
                                        Can I do it all by myself or must i post both bins here because of this model ? i'm not sure
                                        Thanks again for your help...
                                        • Fred2
                                          • Mar 2023
                                          I have a password-protected bios from an HP 650 G1. I have tried RCunlocker and it reads it and says it's unlocked, but it doesn't output a file. I've attached the dump file. Can I get some help or somebody to unlock the bios?
                                          HP Clean VSS2 dumps,fix Endpoint Security error
                                          by SMDFlea
                                          Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                          the infamous **"Endpoint Security" error message.
                                          Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                          I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                          The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                          files.
                                          hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                          filling everything after...
                                          08-08-2024, 03:14 PM
                                          HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 07:12 AM
                                          09-07-2024, 06:40 AM
                                          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:50 AM
