RCUnlocker
    Re: RCUnlocker
    16MB chip on the other side must be modified.
      Re: RCUnlocker
      yes, it work
      thanks!
      all donations are welcome,
      >>>>> click on this link to donate via PayPal. <<<<<
        Re: RCUnlocker
        Attempted on a HP Probook 6450b. (2009/2010)
        Able to read many exact checksum files from chip
        Chip: MX 25L3205D
        note about the error those are hardcoded paths not on my pc, is there an updated version of the tool or source I can compile from?
        Any help is greatly appreciated.
        Error dialog when running the unlocker:
        zip with both before and after bins attached
          Re: RCUnlocker
          Your bios file unlocked.
          Become a Badcaps supporter
          Thanks to all supporters.
            Re: RCUnlocker
            I rewrote the new file and it still has the password on it for me. I'm using a CH341A with 8pin SPI clip.
              Re: RCUnlocker
              for chromebox unlock, changing the dev mode and enrollment set to 0 will not work. the only change is "requisition.remora.gbind. " to ".none.ubind.."
              tried on chromebox 2 and 3 ASUS. both works.
                Re: RCUnlocker
                hi! HP EliteBook x360 1030 G3 writes that it does not support(" Wrong chip try reading and unlocking 16mb chip"), in previous posts it says that it supports(Unlocking HP - ProBook, EliteBook, ZBook (including 32MB models) and Usage: Drag and drop .bin file to .exe file). Help please!
                  Re: RCUnlocker
                  Maybe you have 2 SPI chips, usually it's on the other side of the motherboard, post both here.
                    Re: RCUnlocker
                    It was user error. I was able to get it working after another erase/flash cycle. Thanks Cheese
                      Re: RCUnlocker
                      You are right, there are two SPI chips! The question is, is it possible to flash the firmware without full soldering? I understand, the program removes the bios password or something else? what are the capabilities of the program, what can it do? did not find information anywhere. Thanks!
                      I have two hp 1030. One has a password, the other has no password. Where there is no password, the program erases a certain area after analyzing before and after, the question is what did it erase if there was no password? ) Sorry for the large number of questions, I'm just learning)
                        Re: RCUnlocker
                        Anyone want to clue me in on how to use these probes I purchased from Ali Express?
                          Re: RCUnlocker
                          @Raiderman
                          Please upload one or a few good picture(s) of the probes, as it seems like we all left our crystal balls at home.
                            Re: RCUnlocker
                            Originally posted by AAAC View Post
                            @Raiderman
                            I will, its a page or two back that we discuss the using the probes for wson8 chips
                              Re: RCUnlocker
                              Originally posted by SMDFlea View Post
                              Yes thats a WSON8 chip, don`t use the clip on that,you risk damaging the chip,shorting the surrounding components and cutting through traces.
                              Your options are to desolder it,use a WSON8 pogo pin adapter,or try to solder some thin wires to the protruding solder or traces caps and resistors
                              https://www.aliexpress.com/item/1005003313016522.html
                              These are the probes linked by SMDFlea that I purchased
                                Re: RCUnlocker
                                @Raiderman
                                I suggest to take a look at YouTube, use these keywords "pogo pin WSON8", I do get a few results there showing how to use the probe. I don't include the links here as some videos have advertising.
                                  Re: RCUnlocker
                                  [QUOTE=AAAC;1149670]@Raiderman
                                  Thank you, I will try
                                    Re: RCUnlocker
                                    how to remove computrace for HP elitebook 840 G6?
                                      Re: RCUnlocker
                                      @ogre4273
                                      Use UEFITool NE version and check UEFI Variables, there's usually one named AbtState, that one contains information if Absolute Computrace is Active.
                                      Then use an hex-editor and search for AbtState, a few bytes before the string you will find the header AA553F(h), to invalidate that variable make it AA553C(h), save changes.
                                        Re: RCUnlocker
                                        A general question about flashing an image to the EC. Instead of patching the image in the ROM is it not sufficient to flash the ROM with the manufacturer's copy of the BIOS binary?
                                          Re: RCUnlocker
                                          HP doesn't offer EC. Only main and even that is without ME region.
                                          There is a way to make EC out of main but it needs some knowhow. I've succeeded a few times but would avoid it if possible.
