RCUnlocker
  • dycc
    Vision
    • Nov 2011
    • 626
    • Côte d'Ivoire
    • la maintenance
    #181
    Re: RCUnlocker
    Originally posted by rethoricalcheese
    so nvramactiveregn still?
    yes
    • alfa20fr
      • Jan 2012
      • 34
      #182
      Re: RCUnlocker
      please need unlock
      Last edited by SMDFlea; 12-10-2021, 04:40 AM. Reason: removed bios,posted it multiple times already.........
        • 23289
        Re: RCUnlocker
        Originally posted by alfa20fr
        please need unlock
        Have you tried it,just drag the bios onto the program exe .
        • alfa20fr
          • Jan 2012
          • 34
          #184
          Re: RCUnlocker
          yes but still with password
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #185
            Re: RCUnlocker
            So probably main bios needs cleaning aswell in your case.
            • alfa20fr
              • Jan 2012
              • 34
              #186
              Re: RCUnlocker
              please unlock thanks
              • mido77
                Banned
                • Jul 2021
                • 5
                • Maroc
                #187
                issue with RCUnlocker
                hi sir
                i got this image from a friend in a discord server askinng me to help and as you're the developer of RCUnlocker i thought of sharing this with you maybe you got an answer, thank you
                sorry to disturb with this, just ignore this message if you have no time for it
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #188
                  Re: RCUnlocker
                  maybe he should try renaming his files and folders in a proper way.
                  filename.bin not filename.somethingelse.bin. or foldername not foldername.somethingelse
                  • Gratje
                    • Dec 2021
                    • NL
                    #189
                    Re: RCUnlocker
                    I got a HP elitebook 840 G1. with no bios password. But is this tool also enabling the manufacturing programming mode?
                    At the moment mine is locked. But while booting I'm still getting the:
                    Warning machine is not in committed state
                    because I forgot to add the serial number when I swapped the bios chips on the Main board.
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #190
                      Re: RCUnlocker
                      No, that would be a terrible thing to have on it
                      I found that sometimes just updating bios gets rid of that message (in case you have all serial numbers and such inserted and mpm locked). So try that first.
                      • Gratje
                        • Dec 2021
                        • NL
                        #191
                        Re: RCUnlocker
                        thats the issue, I'm missing 2 parameters. the feature byte and SKU.
                        when it was unlocked I received an access denied message when I wrote the config.txt back with the backup utility configurator tool from HP.
                        Any other way to get the MPM unlocked again to fill it in?
                        • Gratje
                          • Dec 2021
                          • NL
                          #192
                          Re: RCUnlocker
                          Cant edit my previous post.
                          I also have the option to solder back the 2 original SO8 IC's but that has a bios password lock. And the use the RCUnlocker.
                          But can I maybe only solder back the original EC BIOS chip? and Keep the unlocked main bios chip without password?
                          Or should it be a "matched" pair?
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            #193
                            Re: RCUnlocker
                            One will overwrite other. So unlock original main and solder both originals on.
                            • Gratje
                              • Dec 2021
                              • NL
                              #194
                              Re: RCUnlocker
                              Thanks. To be sure I will backup everything before. The new ones and the original ones.
                              • AAAC
                                • Jan 2020
                                • 459
                                • Mexico
                                • PLC's, uControllers, FPGA's, RE...
                                #195
                                Re: RCUnlocker
                                @RethoricalCheese
                                back from post #38 from this thread, answering your question...
                                Question: What clip do you use for wson chips anyway?
                                Answer: You may be able to use this tool for HP laptops, in which they use a WSON8 chip and have SOP8 pads at the sides of WSON chip, the tool will make contact onto the SOP8 pads. To anyone reading this post, just make sure you get the (SOP8) 200mil version of the tool.
                                www.ebay.com/itm/324812073387
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  #196
                                  Re: RCUnlocker
                                  Now that seems like a nice one.
                                  • AAAC
                                    • Jan 2020
                                    • 459
                                    • Mexico
                                    #197
                                    Re: RCUnlocker
                                    @RethoricalCheese
                                    I totally agree. You will just have to keep probe steady while you read/program chip, so a fast programmer will come handy too.
                                    • LatinMcG
                                      Old Soft Member
                                      • Jun 2015
                                      • 73
                                      • USA/Puerto Rico
                                      • Fishing, Fixing, Figuring Out Stuff
                                      #198
                                      Re: RCUnlocker
                                      840 g8 patch i put on notes easy to find hex
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1519
                                        • Estonia
                                        #199
                                        Re: RCUnlocker
                                        Originally posted by AAAC
                                        @RethoricalCheese
                                        Use raspberry pi and flashrom, find the sweetspot for read/write speed. Using a 3v3 LDO which gets power from USB might be needed for G3 to make it more reliable. Haven't tested this onboard on G3 yet.
                                        Make reading as fast as possible by specifying as narrow area as possible (for G3 it's the VSS region for example). Database needed for every model you might need unlocking.
                                        Make a python or bash script to make it all automatic (read, verify, patch, write, verify)
                                        In that case, all of it takes seconds. Maybe 10 or less, I haven't really measured time.
                                        Sorry that I am unable to share this part of the unlocker because I wrote it @ work Just to give you an idea, maybe somebody takes the time to make it happen.
                                        Oh and this is the whole reason I use raspberry. It's darn fast and reliable and makes automation possible. Awful for beginners tho.
                                        • trickystuff
                                          • Dec 2021
                                          • Norfolk
                                          • Electronics, IT
                                          #200
                                          Re: RCUnlocker
                                          Hello!
                                          I registered here just to report success in using RCUnlocker to remove the BIOS/UEFI administrator password on an HP Elitedesk 800 G2 Mini. I de-soldered the BIOS (Winbond W25Q128FVSQ), dropped it into a TL866ii Plus, read it twice, validated it, unlocked it with RCUnlocker, flashed it back, re-soldered and we're good to go.
                                          Thank you RethoricalCheese!
                                          tricky
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                          • Boardview and Schematic Bot
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
