Lenovo 1-14ast-05
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Lenovo 1-14ast-05
    Trying to fix a Lenovo 1-14ast-05 which had a BIOS update interrupted and now powers on with flashing power button and solid caps lock light.
    Downloaded the BIOS update file from Lenovo here:
    https://download.lenovo.com/consumer...s/cwcn23ww.exe
    Then I followed the steps here on how to extract the CAP file using UNIEXTRACT
    https://www.badcaps.net/forum/showth...light=tdk+bios
    Although the directions mention needing to extract twice to get the cap file, but UNIEXTRACT extracted WinFlash and CAP file in one go. I then edited the CAP file in HxD to extract what I thought was the correct 8192KB file and saved it.
    Using CH341A programmer the standard software doesn't appear to support this BIOS model 25U6473F so I downloaded AsProgrammer 1.4.1 from here:
    https://github.com/nofeletru/UsbAsp-flash/releases/
    Read and dumped the BIOS chip with AsProgrammer (attached to this post as Original-BIOS-dump.zip). Then erased chip and flashed the BIN created earlier in HxD (attached here as Extracted-BIOS.zip) but system still won't post.
    Did I miss a step somewhere?
    Thanks.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Lenovo 1-14ast-05
    Originally posted by Vesko356
    I strongly advise you to use AsProgrammer_2.0.0a14, NeoProgrammer V2.2.0.8, or Colibri.
    You didn't edited .cap file as it should.
    Become a Badcaps supporter
    Thanks to all supporters.​
      • 20737
      Thanks.
      Yes you did it wrong but you was on the right track.Delete the first part 0-317 (length 318), then go back over to your backup,scroll all the way to the bottom and use your cursor to select the last line 90 90 E9 FB F4 00 00 00 FE 00 00 00 00 00 F2 FF .Select copy,or right click copy ,then switch back to CWCN23WW ,search for Hex-Values and paste in the hex you just copied (which is the last line of the bios) .Now just put your curser in between the last two FF`s .Right click and select-block ,the end offset will be set to 81FFFF ,enter 0 as the start-offset and click ok.
      Copy and save into a new file,notice that that the selected length is 820,000 ,thats 20,000 too long, so whats going on ? .The clue is at the top of the file,if you look at the right hand side column you`ll see "Insyde Software" in plain text.This update includes the EC as well as the bios.Set the offsets from 0-1FFFF or 0 and the length to 20000 (20000 in hex is 128KB) ,CUT and paste into a new file ,leaving you with a new 8MB bios and 128KB ec.
      Now you need to copy your DMI using the offsets:
      DMI 321000 - 3213FF
      w key 370000 - 3700BF
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        DMI 321000 - 3213FF
        If you followed it ok and made a new bios you can check its SHA-1 hash using Hxd. Analysis -> Checksums -> SHA-1 -> OK
        4FFD7B417FF1F401E52801F314B5D1BDD69C52F3 * .If its the same hash youve done a good job.
        * SHA1 edited to match current topic
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          @Mgrharry - also notice there's a little catch in this exercise (regarding the SHA-1 result) about the Win key block, see the red symbols at the attached image:
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            • bembo91
              • May 2021
              • italy
              Hi, I'm looking for the schematics of this notebook... does anyone have them?
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                This is not the schematic requests forum, its for bios requests ONLY!
                Reminder: rules and organization of this section
                https://www.badcaps.net/forum/showthread.php?t=117483
                • Bowayne
                  • Sep 2019
                  • 32
                  • South Africa
                  Hello, please assist with bootloop issue, on and off no bios screen, it shows fast some words once then bootloop.
                  Here is my dumb
                  Also I tried the above bioses, not working...powerbutton on off on off
                  • peste
                    • Dec 2016
                    • 12676
                    • ROMANIA
                    Here is my dumb
                    read...https://www.badcaps.net/forum/troubl...before-posting
                    • survivalbloke
                      Unable to extract bios file from Lenovo bios exectuable
                      by survivalbloke
                      I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                      Code:
                      "innoextract 7wcn38ww.exe"
                      it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                      The trouble I'm having is that I'm not getting the newly...
                      06-12-2024, 07:55 AM
                    • survivalbloke
                      Unable to extract Lenovo BIOS file from installer
                      by survivalbloke
                      I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                      I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                      How can...
                      07-16-2025, 03:21 PM
                    • Jk KIM
                      Lenovo Ideapad 5 15ITL05 Bios File extract
                      by Jk KIM
                      Hi
                      I need to extract bin file from bios update file which downloaded at Lenovo web site.
                      Pls extract bin file from exe file...
                      I attached exe file!
                      Thx!...
                      02-03-2023, 07:40 AM
                    • Forest79
                      by Forest79
                      However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                      07-23-2023, 07:39 AM
                    • bob113313
                      extract bios dump file from exe Lenovo amd ideapad 5 15alc05
                      by bob113313
                      first of all my apologies for my English (I don't speak it very well, I am French).
                      I am trying to troubleshoot a lenovo ideapad 5 15alc05 ryzen 7 that boots but remains in black screen.
                      I would like to know if anyone knows how to extract the .bin of bios from the exe published on the lenovo site. I have found several information on the internet but they don't work in my case. I think it's because it's an amd.
                      I found some dump on the internet but I don't really trust it. I would like to make a clean bis from the official Lenovo file...
                      12-10-2022, 05:16 AM
