Need BIOS for HP 15s-eq1060nq
  • volinakis
    • Jan 2021
    • 2728
    • N/A
    please I need a working BIOS bin file for HP 15s-eq1060nq motherboard DA0P5MB26A0 REV. A
    Thank you.
  • peste
    • 12719
    • ROMANIA
    Re: Need BIOS for HP 15s-eq1060nq
    Thank you.
    post the backup copy of the original laptop bios
    • volinakis
      • Jan 2021
      • 2728
      • N/A
      here is my problem: I read the chipset BIOS with CH341A software and AsProgrammer and I compared both files with HxD and there are not similar. The chipset is 1.8V W25Q128FW, maybe you can indicate me a reliable software to read the chipset, thank you.
      • peste
        • 12719
        • ROMANIA
        try this too..remove the bios chip from the motherboard before reading or writing..or solder wires between the legs of the bios chip and the programmer
        https://www.badcaps.net/forum/showpo...04&postcount=7
        • volinakis
          • Jan 2021
          • 2728
          • N/A
          I always remove BIOS chipsets and use an adapter to read/write. Anyway, here are the files, thank you in advance.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            ...wires between the legs...
            18+
            Become a Badcaps supporter
            Thanks to all supporters.
            • peste
              • 12719
              • ROMANIA
              try..
              • volinakis
                • Jan 2021
                • 2728
                • N/A
                try..
                I did try bin file you sent me, didn't work - same result: caps lock led blinks 5times long then 3 times short.
                I did try NeoProg, the result is the same as the bin file got with AsProg.
                Thank you very much for your time and effort, I really apreciate it.
                • okraglaczek
                  • Apr 2014
                  • 17
                  • poland
                  try..
                  Your bios is fine, the laptop works. I thank you
                  • Noreddin
                    • Jan 2020
                    • 73
                    • mostaganem
                    Thank you peste
                    • sicilianul
                      • Jul 2014
                      • 70
                      I have a hp 15s-eq1060nq and it shows the message from picture below. The hp System BIOS Update utility doesn't work - winflash.exe won't start on any computer.
                      Any ideas ? If I post a dump of bios could you help me ?
                      https://ibb.co/jMjY8Sp
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11683
                        If you post the bios file + serial number + question you will save a #.
                        • sicilianul
                          • Jul 2014
                          • 70
                          There you go. Dump + SN
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11683
                            HP 15s-eq1000 Laptop PC (183N3AV)
                            • sicilianul
                              • Jul 2014
                              • 70
                              This won't work.
                              peste's bios is working. You will need to disable Manufacture Programming Mode with BCU HP and edit your SN, UUID etc.
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
