Needed Acer F5-572G Bios
  • ProSis
    • Jun 2017
    • 86
    • Turkey
    What I found on the net did not work, either it belongs to uma or a different device. Does anyone have the bios for this motherboard?
    Motherboard code : DA0ZRWMB6G0 Rev G
    GPU : N16V-GM-B1
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    Re: Needed Acer F5-572G Bios
    GPU : N16V-GM-B1
    try this bro
    • EbrahimSiami
      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
      by EbrahimSiami
      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
      **What I have tried so far:**
      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
      07-02-2025, 02:31 PM
    • NecroFlex
      Acer Aspire 1 A115-32-C28P BIOS needed please
      by NecroFlex
      I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
      I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
      I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
      02-11-2025, 08:51 AM
    • Wg188
      ACER Veriton Z4660G AIO bios help
      by Wg188
      I have an Acer veriton Z4660G all in one pc,
      Model: Z4660G-I5850H1 (VZ4660G_W)
      Need bios dump and schematic would save my life !
      to make a long story short I bought this all in one used
      with a broken lcd, with the objective of making a custom desktop out of it
      ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
      06-17-2023, 02:20 PM
    • tlindi
      Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
      by tlindi
      Sublect line continuation: ... Jaguar IDS PC aka Panasonic
      >Read BIOS guides, methods, resources and tools
      Ack
      >Try the method at BIOS guides, methods, resources and tools before requesting help
      Ack
      >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
      python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
      01-30-2025, 04:26 AM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
