Thank you
eda50 la-h271p bios help please
Hello everyone, help remove the password pls
service tag: 4NH6H53-8FC8
EDA50 LA-H271PAttached FilesComment
1st boot, press F2, write service tag, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing modeAttached FilesComment
I WANT TO CLEAN THIS BIOS PLEASE
ST DR42N33
DELL PRECICION 7540
read...https://www.badcaps.net/forum/troubl...before-postingOriginally posted by shetosST DR42N33
DELL 7540
LA--H271PDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hello my friend
I need bios for dell precision 7540
EDA50 LA - H271P REV : 1.0 ( A00)
My Laptop work ok power and data but when i shut down it , it not work power just orange light on led power
i used a lot of bios but no result it work power and data for one time but when i shut down it , it not work power and data until i left it for some time and it work again for one time
service tag 31JSF13
i upload orginal biosAttached FilesComment
Precision 7540Hello my friend
service tag 31JSF13
Service Tag: 31JSF13
​Attached Files↵
​https://www.badcaps.net/donateComment
after i programe the file that you uoload , i read the file agin and compare with the file you aplouad it , there are a lot of different
i prgrame your file agine and read it after programe it and before solder it on motherboard , and compare it , it is the same and no different
but after i solder it and turn on the laptop the service tag is not correct and the same problen the laptop is turn on one time power and data , i have to left it some time and try again then it work one time again
any help or the problem not bios ?Comment
My laptop has computrace. I cannot use it.
Remove computrace please.
Dell Precision 7540
S/T: 4VZRL13
EDA50 LA-H271P
Rev: 1.0 (A00)
Thanks,Comment
Computrace removedAttached Files↵
Dell Precision 7540
S/T: GLCXK33
EDA50 LS-H271P
Rev: 1.0 (A00)
Hello. No realtek sound in OS.
After bios downgrade to version 1.8.3 laptop has such problems:
1. Shows message "Alert! Service mode jumper is set" during every boot. And ME Flash Descriptor is unlocked in OS.
2. Realtek chip and its devices are not detected in Windows(device manager) and Ubuntu. But speakers work(beep) in built-in diagnostics. Those speakers' pins are connected directly to codec so it seems to be alright.
So far I:
1. Flashed different ME cleaned dumps with SPI programmer. Some of them showed the same message and descriptor was unlocked. Some of them didn't show the message and descriptor was locked. But in both cases no realtek showed in OS.
2. Measured resistors on HDA lines from CPU to PCH and from PCH to codec, they seem to be OK. Also I cleaned motherboard.
Can something be done to provided bios dump in this sound regard?​Attached FilesComment
It was done by bios.exe updater from dell support page. After that I tried to downgrade or update in the same way but results were the same no sound and the message .
Also I noticed that message and ME descriptor thing appear depending on which dump was initially flashed in chip and persist after downgrade/update of this initial dump via dell update exe to every version of bios.Comment
try this bios.
Also I noticed that message and ME descriptor thing appear depending on which dump was initially flashed in chip and persist after downgrade/update of this initial dump via dell update exe to every version of bios.Attached FilesComment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
