need bios dump of dell latitude 5320
  • IMLJ
    • Jan 2015
    • 25
    Originally posted by rex98
    try. 1st boot press F2, write service tag, disable Absolute, apply changes, restart. 2nd boot press alt+F to exit factory mode
    thanks for your help, I have tried and the laptop restart a few times and then off. black screen with fan max speed. pressed F2 but nothing came out of the screen...very strange......
    • sancheti81
      • May 2014
      • 191
      • India
      #242
      Originally posted by IMLJ
      Pls help unlock admin password and disable absolute.
      ST:41FPTG3
      EX:8793994323
      thanks.
      try this and post result
      • rex98
        • Feb 2023
        • 1281
        • Mandaue CEBU, Philippines
        #243
        try that two.
        • rex98
          • Feb 2023
          • 1281
          #244
          this bin is same as here https://www.badcaps.net/forum/troubl...64#post3214864
          • IMLJ
            • Jan 2015
            • 25
            try that two.
            Thanks for your help. this one is the same issues as rex98 attached, black screen max fan..
            • IMLJ
              • Jan 2015
              • 25
              try that two.
              thanks again, the first one "clearme.bin" is working but it has service tag changed and also has lock on it, just same as my original one.
              the second one i flashed and seems unlock and let me put service tag in after apply change, the computer refused to turn it back on even I flashed back to the ori bin.
              Now the lapotop is stuck at 5V. lol..I dont know if I heated somewhere when I was removing the chips. I have to fix the board now...do you have a schematic for it ?lol....
              • rex98
                • Feb 2023
                • 1281
                #247
                try this again.
                • IMLJ
                  • Jan 2015
                  • 25
                  try this again.
                  Thanks so much for your help, I believe the second one of that two bios is working, just my laptop is dead. i cant tell, but it worked at the beginning then my laptop cant turn on.
                  • volinakis
                    • Jan 2021
                    • 2747
                    • N/A
                    #249
                    try this one, after soldering bios CONNECT INTERNAL BATTERY then AC Adapter an let it run for 2 minutes, it will restart several times with no image. Remove CMOS battery before soldering bios.
                    • bykanovm
                      • Aug 2022
                      • 95
                      • Украина
                      #250
                      I have this problem. The laptop was completely working, I tried to unlock the BIOS password. I flashed the BIOS chip several times and the laptop turned on. But at some point the microcircuit failed. I ordered new microchips. The problem is that the laptop is now in a mode I don't understand. If I flash the original BIOS, the laptop turns on, but the screen flashes gray, red, green and blue. After which the laptop turns off. The indicator flashes white 6 times and orange 3 times. I read on the DELL website how to exit this mode using the Ctrl+Esc key, but nothing changes.
                      Here is my original BIOS with password.
                      SerTag J1C35B3
                      EX 41439632799
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        #251
                        ❤️YOU MUST:
                        ❤️Provide the full machine model number, serial number (or Service tag, SNID)❤️
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          #252
                          SerTag J1C35B3
                          EX 41439632799
                          Service Tag: J1C35B3
                          Try a new build
                          • bykanovm
                            • Aug 2022
                            • 95
                            • Украина
                            #253
                            Try a new build
                            With your BIOS, the laptop does not turn on at all and no indicators light up.
                            • rex98
                              • Feb 2023
                              • 1281
                              #254
                              try. i also clean me region and patched.
                              • bykanovm
                                • Aug 2022
                                • 95
                                • Украина
                                #255
                                Dear, thank you very much! The laptop is working!
                                • Ramonay
                                  • Jan 2024
                                  • 8
                                  • philippines
                                  #256
                                  Originally posted by minhdigital
                                  Send to you, try
                                  thanks for responding. tried it but laptop not powering on. not charging when charger is plug in.
                                  please help. thanks
                                  • rex98
                                    • Feb 2023
                                    • 1281
                                    #257
                                    please help. thanks
                                    1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
                                    Give feedback pre.
                                    • Ramonay
                                      • Jan 2024
                                      • 8
                                      • philippines
                                      #258
                                      Hi rex98. i tried the patched, all good and working. thanks. patched_latitude53208FC8.rar
                                      • justice171
                                        • Feb 2018
                                        • 101
                                        • South Africa
                                        #259
                                        I have a Dell Inspiron 15 3000 with the ST: 2GWVVG3 ( Latitude 5320), but the motherboard is LA-K032P very confusing, but hear my problem.
                                        When I turn it ON it shows a light on Caps Lock for about 20 seconds then goes OFF.
                                        Please help with the BIOS
                                        Attached is the Backup BIN.​
                                        • wwbielsko
                                          • Aug 2008
                                          • 59
                                          #260
                                          Hi, can I ask for new builded bios for:
                                          DELL 5320
                                          motherboard 19817-1 SOUTH PEAK 13 10L
                                          ST: GKX83B3
                                          EX: 36093645759
                                          I think that my dump went wrong and after removing password and flashing, my laptop wont run. Couple restarts, and black screen backlight only with restarts.
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                            DELL Latitude 5320 2in1 Hybrid (2-in-1) 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5320 2in1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5320 2in1 boardview and 5320 2in1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 03:40 AM
                                            DELL Latitude 5320 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5320 boardview and 5320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5320...
