please clean me and updated bios for HP 14-CM0105AU
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Laptop model
    hp 14-cm0105au
    sn# 5cg9070nn4
    board
    14-fp5-6l-gddr5x2
    hagrid-6050a2983601-mb-a02(a2)
    backup
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    HP 14-cm0105au BIOS dump
    Hello guys.. need help here.. BIOS dump of HP 14-cm0105au
    25Q128FWSQ
    Thanks in advance
    Never stop LEARNING because life never stops TEACHING!
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      Re: HP 14-cm0105au BIOS dump
      Originally posted by duranitron
      hello guys.. Need help here.. Bios dump of hp 14-cm0105au
      25q128fwsq
      thanks in advance
      match your bid and flash
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        thanks.. i already tried it.. both bin are not working.. here is my original
        bios.. can someone create clean me i truly appreciate it.. thanks in advance...
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          thanks.. I already tried it.. Both bin are not working.. Here is my original
          bios.. Can someone create clean me i truly appreciate it.. Thanks in advance...
          try again
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            try again
            thanks..
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • haitham sharabati
              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
              by haitham sharabati
              Hello engineers 😀,
              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
              💀 Problem:😅
              - Device shows “Administrator Password”...
              08-07-2025, 04:54 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
