Re: Dell Latitude 7480 Bios Password
I had 3 with Nordic layout and only in that way it worked, using right Shift for uppercase.
He shoots, HE SCORES!!!
Thanks for your help hoaca388, using Capslock for the upper case letters worked a treat.
I used the password for the 6FF1 suffix and it worked the first time.
Have a great afternoon (or whatever time of day it is in your timezone)Leave a comment:
Evening, (well, it is here anyway) I'm a bit lost.
My system number is 16PPRQ2-6FF1
I've tried the number from bios-pw, I've changed the suffix to BF97 and tried that number too. neither work.
I don't have a US keyboard to try to enter it with that, is there anything else I can do to try and get rid of the pesky admin pasword?
Thanks in advance
and I've confirmed that there are 16 *s on the passwordLeave a comment:
Thanks in advanceLeave a comment:
I have a dell 7480. code F401PH2-6FF1
the WEBRctB5Uw8CbGZs on bios-pw.org doesn't work (I had tried it many times). pls, help me.Leave a comment:
@ok67- Post your generated passwords.
- Count how many stars/asterisks are printed on the screen when you do the CTRL-ENTER-ENTER, there must be 16.
- Upload a picture of the password screen. The master password works best at the System Password prompt “This computer system: #1NF80X2-E7A8, is protected by a password authentication system…”.
The point is, I was on a business trip and used laptop keyboard. At home I used external USB keyboard. It could be a reason why the password was not accepted. Now is everything fine.
Thank !Leave a comment:
hi,
HX5QNQ2-E7A8
i got this code
and gave me these
JI[91J16dJZj4bLk
DGyq2GzzRGL5c7dJ
not worked.
do i need to change the last 4 digits to some magic number or is there some sequence/conversion for this?
thanx in advance
edit: when typed lower case, it gives different pair of codes
e0eyPQN12M516N3R
[Qrr2mkp4IQQyn4G
also doesnt work.Leave a comment:
HX5QNQ2-E7A8
i got this code
and gave me these
JI[91J16dJZj4bLk
DGyq2GzzRGL5c7dJ
not worked.
thanx in advance
e0eyPQN12M516N3R
[Qrr2mkp4IQQyn4G
also doesnt work.Last edited by mysticusa; 07-01-2022, 07:00 PM.Leave a comment:
Hello, I need help. Can someone clear me region in my dump? Thank you in advance.Last edited by SMDFlea; 04-12-2023, 01:13 PM.Leave a comment:
- Upload a picture of the password screen. The master password works best at the System Password prompt βThis computer system: #1NF80X2-E7A8, is protected by a password authentication systemβ¦β.
I have 1NF80X2-E7A8. Tried mentioned password generator. Received two passwords, held Ctrl and pressed Enter twice. Without success by both. User qwerty and qwertz. Used O instead of 0. Nothing helps.
Any idea how to remove bios password ?
Thanks in advance.Leave a comment:
Great thank you!
PW G4kkr3LmMJXINr10 worked fine!Leave a comment:
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, π π π ...-
Channel: BIOS Requests ONLY!
by ElBock_Hello,
I just got my hands on an almost new dell latitude 7480. Issue is that its previous owner didn't give me the bios pasword.
Can you help me unlock it ?
System Number is FKL4SQ2-6FF1. I've already tried https://bios-pw.org/
Thanks !-
by anlsmithI am trying to remove the BIOS password for a Dell Latitude 5430 motherboard LA-L591P. So far I think that I have located the BIOS chip but NeoProgrammer says that is detects 3 chips. I have attached the dump from each one. Are any of these the BIOS file? Service Tag: 1DMC1T3. If nyone knows the exact location of the bios chip as well I would greatly appreciate it...
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
- Loading...
