Panasonic CF53 MK4 CF-532S74RMG
  • noumenon
    replied
    Re: Panasonic CF53 MK4 CF-532S74RMG
    hello,
    at the book are label: CF-532S74RMG with serial: 5JTCA29901
    as I buy it there was in BIOS (V4.00L18 M91 the Serial: 5KTCA37037
    so I think there was some mod before me and the WWAN and WLAN does not work. Wireless switch was disabled and not working (also LED still off).
    I search a lot of ROM here and test...a lot of them enables the wireless switch but only WWAN comes on
    here the original backup ROM from book at first day (with PW and wireless switch disabled!).
    with kind regards
    Mike
    replied
    Originally posted by noumenon
    hello,
    yes, the mechanical switch at side of book is on and also the LED is working. With switch I can enable WWAN on/off or like it called "flightmode on/off". So it seems to be ok.
    Still the WLAn card's will not regonize in any way, not bios, not windows. In BIOS I have menu for WWAN (enable/disable) but nothing for WLAN, thats curiouse
    with kind regards
    Mike
    Are you sure youve got the exact same model as in the thread title. Do you have a copy of the Original backup .
  • noumenon
    replied
    hello,
    with kind regards
    Mike
    replied
    hello,
    I'am back from holiday. I tested 6235, 7260 and 7265Intel unbranded cards and nothing is regonized, still no WLAN
    Any hints?
    With kind regards
    Mike
    i assume you`ve turned the wireless switch on
  • noumenon
    replied
    hello,
    Any hints?
    With kind regards
    Mike
  • noumenon
    replied
    The last file I used is now here. ME is working, WWAN is working, still no WLAN but I buy two other Types and will test next time...
    with kind regards
    Mike
    replied
    Now I try new WLAN Card and still no option/function/Finding
    Is it maybe problem with the base (532S74RMG) or the option "2.LAN" that WLAn is not possible?
    best regards Mike
    Post your original backup, the one before you made any changes to it .
  • noumenon
    replied
    best regards Mike
  • noumenon
    replied
    hello,
    I read and learned a lot here. Many Thanks for that!
    Now I'am at the point, that the book is working fine, wireless switch is activated and WWAN detected. WLAN I will change soon, I think it is defect.
    I flash with CH341a and clip without any soldering an other bios from here, what in description was free of PW, BUT:
    ----- just 4 info -----------
    I had an PW in the old bios set and I think that was reading out from somewhere in the book, so If I try to enter the BIOS I was not able to go in, because the "data" in bios was clear and the "data" from somewhere not, both missmatch...
    I read out my backup from original bios and set the same values inside the new bios and that it works..easy for you but for me something learnd
    Now I enable all menu with the "magic string" and have working book..so far so good, BUT:
    Question: is it possible to enable ME? I have only "n/a" as info in BIOS and no skills to understand for what is ME usefull, is it problem to work without?
    with kind regards
    Mike
  • noumenon
    replied
    hello,
    one question: is it possible to flash the bios with AFUWIN or any other tool without external programer? Or if not, is there any tutorial? I have the skills for bonding and using MC's but here I'am newbee
    My problem: I have a CF-532S74RMG with bios inside where the WLAN and WWAN function isn't enabled and no option inside the bios to change that.
    Maybe you know where I can enable this funktion in the hex-dump?
    with kind regards
    Mike
  • Maxpower3
    replied
    Originally posted by SMDFlea
    The serial is stored in the ME region in one of the partitions.
    yes but search and look just with text 5KTCA or 5JTCA
    there are lots of little bits of serial everywhere
    the last digits are coded on 16bits little-endian to ascii
    look at the number of times found serial on my picture
    replied
    Originally posted by Maxpower3
    yes but written many times in several ways and I don't know if any checksum to verify.
    My original patched file is working fine?
    So better to start from an original file and modify it my way if you have other pc to do. You keep the original file like that
  • LenBios
    replied
    yes your file is working very good
  • Maxpower3
    replied
  • LenBios
    replied
    look
    yes correct
    can i change the SN with Hex editor?
  • Maxpower3
    replied
    Originally posted by LenBios
    the SN in #26 is 5KTCA36745
    in the post#16 is: 5JTCA30882
    look
  • LenBios
    replied
    Thank you for all your help
  • LenBios
    replied
    0xAB3B12 and 0xAF3B14
    do an AMITSESetup text search with hxd
    Just compare your file with hxd program , look around now, i've done all the work for you already
    thank you very very much for your help.
    if in the future i have same panasonic model can be done in this way?
    Thank you
  • LenBios
    replied
    The DMI was copied from the bios at post #26 !!!
  • Maxpower3
    replied
    which lines are AMITSEtup?
    Thank you very much
    this one is working with orig
    @Maxpower what did you change in this file from the original?
    Can you please send pictures which line have to fill zero etc?
    Thank you
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
  • aa10aa10
    Panasonic Toughbook CF-33 mk1 BIOS repair
    by aa10aa10
    Good day,
    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
    01-21-2025, 06:13 AM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • James Jackson
    Panasonic CF-20G0247VM BIOS Bad Flash Help
    by James Jackson
    I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
    Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
    05-01-2025, 11:28 AM
  • outsider
    Panasonic FZ-G1 MK5 - BIOS password returning
    by outsider
    Hello
    I removed the BIOS password thanks to the help of one of the friends of this forum.
    https://www.badcaps.net/forum/troubl...61#post3637661
    The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
    06-17-2025, 12:51 AM
