IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • Bios Cracker
    • Oct 2024
    • 309
    • India
    #341
    Originally posted by antiogu
    Hi everyone
    i have a lenovo V15-ADA
    Model 82C7
    Serial PF2CZ1AN
    MTM 82C7S00B00
    after updating the bios the LEDs light up, the fan spins but nothing else happens, i saved my bios can you help me?​
    IdeaPad 3 V15-ADA Laptop (Lenovo) - Type 82C7ADA
    • antiogu
      • Mar 2014
      • italy
      #342
      Tank you
      • pblenov541
        • May 2025
        • 5
        OK so I've studied the procedure in particular with this video but I don't have a backup of my previous bios healthy, it's corrupt because it was badly flashed precisely.
        https://youtube.com/watch?v=NyjflvtmAYA
        So how can I start from scratch with an old blank bios and transfer my information to it to generate a special bios with custom dmi? Thanks
        • antiogu
          • Mar 2014
          • italy
          #344
          sorry when sending the file I uploaded the faulty one that was half written. I downloaded the official bios update directly from the lenovo site, can you help me again? thanks
          V15-ADA
          Model 82C7
          Serial PF2CZ1AN
          MTM 82C7S00B00​
          • pblenov541
            • May 2025
            • 5
            Originally posted by hoaca388
            Here
            Can you send me same file with my informations please ?
            Ideapad 3 15ADA05
            MODEL name: 81w1
            SN: PF3NTMCG
            MTM: 81W1002GFR​
            • hoaca388
              Badcaps
              • Jan 2022
              • 11348
              • Viet Nam
              #346
              Ideapad 3 15ADA05
              MODEL name: 81w1
              SN: PF3NTMCG
              MTM: 81W1002GFR​
              Where's your dump ?
              https://www.youtube.com/results?sear...mer+how+to+use
              • hoaca388
                Badcaps
                • Jan 2022
                • 11348
                • Viet Nam
                #347
                Ideapad 3 15ADA05
                MODEL name: 81w1
                SN: PF3NTMCG
                MTM: 81W1002GFR​
                See # 346
                  • 20411
                  Ideapad 3 15ADA05
                  MODEL name: 81w1
                  SN: PF3NTMCG
                  MTM: 81W1002GFR​
                  Post your backup in a zip or rar ,attach it directly to your post, don`t post external links please.
                  • zimako
                    • Oct 2022
                    • 7
                    • france
                    #349
                    I'm having the same problem as you: no image, even though the PC seems to boot normally.
                    I hope this helps someone, as I've solved my problem.
                    If you've read this thread, try reprogramming the BIOS. You've checked, as others have indicated, that DIMM_only is enabled (presence or absence of resistor on the motherboard). So you may have the same problem as me.
                    At the SODIMM slot where the memory stick is inserted, the pins at the ends (left and right) were unsoldered.
                    A solder point, and the PC works perfectly.
                    • pblenov541
                      • May 2025
                      • 5
                      i attach rar file
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11348
                        • Viet Nam
                        #351
                        i attach rar file
                        Fault backup .
                        • antiogu
                          • Mar 2014
                          • italy
                          #352
                          V15-ADA
                          Model 82C7
                          Serial PF2CZ1AN
                          MTM 82C7S00B00
                          Can anyone help me?
                          • peste
                            • 12290
                            • ROMANIA
                            #353
                            Can anyone help me?
                            Three users answered you...either you are not writing the correct bios or the laptop has another problem...
                            you have everything you need at post #341...
                            • zetz
                              ZETZ
                              • Jan 2022
                              • 6
                              • colombia
                              #354
                              Hi colleagues, I need the firmware for the EC IT8227e-128 on my NM-C821 motherboard. I would appreciate it if you could help me with that firmware, as I need it urgently. Thank you very much.
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1187
                                • France
                                #355
                                Serial number /model type etc .........
                                Respect rules please
                                I found this in bios update but not sure if it works​
                                • gandz1234
                                  • Nov 2019
                                  • Poland
                                  #356
                                  My Lenovo 17ADA05 has black screen issue. No fan spin and lights are on.
                                  Maybe somebody could help fix bios. All info attached.
                                  IdeaPad 3 17ada05
                                  SN PF26038B
                                  MTM 81W20016PB
                                  • doivaythoiem
                                    • Jun 2024
                                    • 95
                                    • Việt Nam
                                    #357
                                    IdeaPad 3 17ada05
                                    SN PF26038B
                                    MTM 81W20016PB
                                    Try And Feeback
                                    • amitswami
                                      Delhi
                                      • Aug 2021
                                      • 42
                                      • rajasthan
                                      #358
                                      Lenovo V15-ADA NM-D151 Rev 1.0
                                      SN: PF1X22LV​
                                      PALES REPAIR THIS BIOS
                                      • doivaythoiem
                                        • Jun 2024
                                        • 95
                                        • Việt Nam
                                        #359
                                        SN: PF1X22LV​
                                        try and feedback
                                        • amitswami
                                          Delhi
                                          • Aug 2021
                                          • 42
                                          • rajasthan
                                          #360
                                          Originally posted by doivaythoiem
                                          try and feedback
                                          thank you boss working 100%
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • Patriarxis
                                            Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                            by Patriarxis
                                            Hello.
                                            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                            It takes 0.027A and the power button flashing.
                                            All the voltages on the board are ok. 3.3, 5 etc.
                                            Also is charging the buttery .
                                            What else i can check?​
                                            05-26-2025, 01:03 AM
                                          • hotcrossedbuns999
                                            IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                            by hotcrossedbuns999
                                            First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                            Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                            05-21-2025, 05:59 PM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • Visual_vt
                                            Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                            by Visual_vt
                                            Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                            SSD and BIOS seems to be OK.
                                            Thank you....
                                            12-30-2024, 09:14 AM
