Dell Latitude 5400 Bios password
  • g_george_n
    • Aug 2025
    • romania
    #801
    One more thing, I know how to remove the chip from the board, but I'm asking you guys because you're specialists and I don't want to ruin them.
    • Kinshir
      • Jul 2025
      • 8
      #802
      Hello you can try this new build bios from your corrupt original bios good luck ....
      Hello and thank you very very much,
      This last build worked, I managed to push it to the laptop and did a double verification and it started and it works.
      What did you do, how did you do?
      Thank you very much!
      • BIOSSASI
        Creator 💀
        • Dec 2023
        • 32
        • SRILANKA
        #803
        Anyone Who Need CLEAR ME For "DELL LATITUDE 5400 EDC41 LA-G892P REV 1.0 32MB"
        Enjoy
        Patched BIOS Only For EDC41 LA-G892P REV 1.0 32MB
        Again Confirming This is Only For 32MB ( 32,768 KB )
        01.Flash
        02.Connect Power Adaptor & The Flashing ME will be start Automatically.
        Some Updated ME will Directly Boot ! Dont Worry
        NO DELAY BOOT , NO HANGS , NO BUGS !!!
        Have a great Day !
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • peste
        • 13335
        • ROMANIA
        #804
        Enjoy
        01.Flash
        Have a great Day !
        post S/N, full name and model, motherboard model,TYPE,etc.
        • Kinshir
          • Jul 2025
          • 8
          #805
          Hello again,
          Is there a way to check if a Dell Bios .bin file is corrupted or any tool for this matter?
          • BIOSSASI
            Creator 💀
            • Dec 2023
            • 32
            • SRILANKA
            #806
            Enjoy
            01.Flash
            Have a great Day !
            Sure ! sorry , Mistakenly Posted as a new topic. Thank You.
            • Alejandro Luo
              • Apr 2025
              • Spain
              #807
              I’m trying to read (backup) the BIOS from a GigaDevice GD25Q256DYIG (3.3 V) on a Dell Latitude 5400 (LA-G892P, 2019).
              My setup:
              • CH341A (black), hardware-modded to output 3.3 V (because at 5 V it wouldn’t read).
              • NeoProgrammer on Windows (the CH341A is detected fine).
              • SOIC8 clip (to avoid desoldering).
              • I also have a 1.8 V adapter (only to test behavior; I know the chip is 3.3 V).
              Problem:
              • With the CH341A plugged in, NeoProgrammer sees the programmer.
              • The moment I clip onto the BIOS chip, Windows plays the USB-disconnect sound and the CH341A drops off the bus.
              • If I insert the 1.8 V adapter, the USB doesn’t disconnect anymore, but of course the chip won’t read because it needs 3.3 V.
              So far I’ve tried many things (different USB ports/cables, slower SPI speed in NeoProgrammer, etc.). My suspicion is a power/voltage/current issue or in-circuit loading from the motherboard.
              Questions / Help wanted:
              1. Has anyone seen this exact behavior (CH341A disconnects when clipping on at 3.3 V, but stays connected at 1.8 V) and found a fix?
              2. Is this likely the motherboard back-feeding / overloading the 3.3 V rail when I inject 3.3 V from the CH341A?
              3. Would you recommend isolating VCC (lifting pin 8) or just desoldering and reading off-board?
              4. Do I need pull-ups on /WP and /HOLD, or any specific wiring tweaks for this model?
              5. Any checklist to confirm proper pinout/contact on WSON-8 (if this package is WSON on this board), since a SOIC clip might not make good contact?
              If someone had a similar case and solved it, I’d really appreciate your guidance. Thanks a lot!
              • hoaca388
                Badcaps
                • Jan 2022
                • 12237
                #808
                Originally posted by Alejandro Luo
                My setup:
                Problem:
                Have you removed the main battery and cmos battery ?
                ​https://www.badcaps.net/donate
                • Alejandro Luo
                  • Apr 2025
                  • Spain
                  #809
                  all battery had been removed and the cmos battery also
                  • luisvalenzuelajr
                    • Jun 2015
                    • 66
                    • Brasil
                    #810
                    Hello, I need to fix the TPM error in this BIOS, please.
                    Dell 5400, MB g891p 1.0, ST GTFRV6S
                    • Wood204
                      • Aug 2025
                      • Spain
                      #811
                      Help please
                      I have a CH341A black programmer and using a clip, but the bios chip it isn't recognise. It is a winbond 25q256jveq in a laptop dell latitude 5400. I used CH341A 1.43 version and NEO Prog 2.2.10
                      Thank you for the reply
                      • LBTT1121
                        • Nov 2024
                        • 691
                        • Việt Nam
                        #812
                        try and feedback
                        • luisvalenzuelajr
                          • Jun 2015
                          • 66
                          • Brasil
                          #813
                          Originally posted by LBTT1121
                          try and feedback
                          Thanks for the reply, I tested it and I still have the tpm error.
                            • 21586
                            check the service tag again, is it GTFPV63 ?
                            • luisvalenzuelajr
                              • Jun 2015
                              • 66
                              • Brasil
                              #815
                              The label is very difficult to read, but in principle it is GTFRV6S
                              • luisvalenzuelajr
                                • Jun 2015
                                • 66
                                • Brasil
                                #816
                                I just checked the correct one is GTFPV63
                                • luisvalenzuelajr
                                  • Jun 2015
                                  • 66
                                  • Brasil
                                  #817
                                  some help please
                                    • 21586
                                    some help please
                                    Test this one.
                                    • luisvalenzuelajr
                                      • Jun 2015
                                      • 66
                                      • Brasil
                                      #819
                                      Test this one.
                                      thanks for replying, the bios works but TPM error remains
                                      • luisvalenzuelajr
                                        • Jun 2015
                                        • 66
                                        • Brasil
                                        #820
                                        some help please
                                        • jhanra
                                          by jhanra
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                          DELL Latitude 5400 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
                                          09-06-2024, 12:13 PM
