Pls! The bios file needs to be me clean. Monster A5 V13.1
  • ProSis
    • Jun 2017
    • 87
    • Turkey
    There is a late boot problem on my computer whose chipset was changed. About 1 minute, but the image comes out. I tried to do it myself but for some reason I did not succeed. I need help.
    Monster A5 V13.1
    Mainboard : GI5CNXA V1.0
    Org rom
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Pls! The bios file needs to be me clean. Monster A5 V13.1
    Monster A5 V13.1
    Org rom
    next time post the copy of the bios here ,, not on another site ... try this ..
    • to5it0
      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
      by to5it0
      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
      I have opened the laptop and identified the main BIOS chip...
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • m1ch43lzm
      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
      by m1ch43lzm
      Hi everyone
      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
      There's also an extra OTP Secu.R...
      09-06-2025, 05:47 PM
    • Forest79
      by Forest79
      However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
      07-23-2023, 07:39 AM
