X430 samsung need working bios
  • radaxs34
    • Feb 2020
    • 31
    • PHILIPPINES
    model: X430 samsung
    board model: NYKS 94V-0 NM14 103403A
  • peste
    • 12933
    • ROMANIA
    Re: X430 samsung need working bios
    Originally posted by radaxs34
    model: X430 samsung
    try..
    • Firekid
      • Apr 2023
      • Nigeria
      Pls I need bios file for Samsung X430
      Board model:nyks nm4 94v-0 0934 2a
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Upload your bios backup, or try the bios attached in post #2.
        Become a Badcaps supporter
        Thanks to all supporters.​
        • Firekid
          • Apr 2023
          • Nigeria
          It is not the same with post 2
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Where is your bios backup? Issue description, serial number, full model name, and so on?
            • Adetech583
              • Jan 2023
              • Nigeria 🇳🇬
              Samsunng bios file needed NYKS NM4 94-0 0934 2A
                • 21137
                Are you two related somehow .Anyway, post your bios backup
                https://www.badcaps.net/forum/showpo...04&postcount=6
                • Kjell
                  Samsung Series 9 - BIOS issue
                  by Kjell
                  After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                  Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                  08-01-2025, 09:15 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • zPwN!
                  ENOVA NE14I310 XU133t rev 1.3 working BIOS
                  by zPwN!
                  Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
                  Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
                  System SKU NE14I310
                  BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
                  Motherboard XU133T rev 1.3
                  Serial Number IPNBI3X240SM2A01095
                  Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
                  RAM 8.00 GB
                  NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
                  01-03-2025, 01:03 AM
                  by Vesko356
                  08-11-2023, 03:27 AM
