Dell 5580 CDM70 LA-E081P Rev 2.0 + EC request
Dell 5580 CDM70 la-e081p rev 2.0 service tag F8NYFH2
Please assist with bios fix, its working its has a tpm error on startup , bios doesnt have any option to remove it.
Also would be nice to assist me in how to fix it as I have others with the same issue so I can learn.
Andreasbest Try my bios hopefully it worksComment
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
Channel: BIOS Requests ONLY!
by mferna14Hi all., I just replaced the new motherboard (Bucky/BenSolo WHL/CNL MB 17859-1) for Inspiron 15-5580 Service Tag: BRJ9KT2 Express Service Code: 25609552022 . The above is the original Service Tag, but when it boot up with the SSD it ask me for Bit Locker password. I know once I have the correct service tag embedded in the bin file, the SSD will not boot up in the bit locker menu. Can anyone please change the service tag for me. The attached Bin file is 100% working, only kindly change the requirement so that the Bit Locker screen does not appear. Thanks in advance....
by Rudra2002So, I have a dell g15 5530 i7-13650HX and RTX 4060.
I tried to update the vBIOS from this link and something failed https://www.dell.com/support/home/en...15-5530-laptop
I have the logs and everything but now the vbios is corrupted. I tried to flash with the dell firmware tool but it crashes after it says reading the eeprom.
Can any one please share the vbios of there laptop with the same specs please so that I can use nvflash. I am kind of scared and would really appreciate if anyone...-
- Loading...
