please i need bios for 14m-dw0013dx (LAIKA-6050A3156701-MB-A01(A1)) please i have attached the dump.
HP 14m-dw LAIKA-6050A3156701-MB-A01 bios
Re: 14m-dw0013dx bios
The dump is not good ,, I would try to do it one, two times and compare the image ... When placing the dump into MeAnalyzer it gaves me "File does not contain Intel Engine/Graphics Firmware"
14m-dw0013dx should be Intel I3 Cpu I think ...
here is some dump to try ... but there is maybe some problem with reading your dump, make sure to do proper backup. -
thank you Senior. but please it didnt work. is there any alternativeThe dump is not good ,, I would try to do it one, two times and compare the image ... When placing the dump into MeAnalyzer it gaves me "File does not contain Intel Engine/Graphics Firmware"
here is some dump to try ... but there is maybe some problem with reading your dump, make sure to do proper backup.Comment
Check the bios you posted at #2 with MEAnalyzer ,the ME firmware is initialised ,meaning its "dirty" ,already booted on another machine.It needs cleaningComment
Well still it should work ... late display etc.,, but he did not said IF the laptop has turn on or If it was dead not turning onComment
Try this one. Virgin bios extracted from sp112835.exe https://support.hp.com/gb-en/drivers...Flag=true&sku=
plus your DMI + win key added from your corrupt backup.Attached FilesComment
Official HP Extracted DUMP ... in Configured state
Ok ... to late
but may be handy for other people without DMI info
Attached FilesLast edited by matusiq; 06-03-2021, 10:32 AM.Comment
Hello dear forum participants,
I am looking for EC.bin and Bios
(Laptop: x360 Pavilion HP-14-dw0156ng)
SN: 5CG0250LNP
ProdID: 1B2C1EA#ABDComment
Read the rules before posting
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
post S/N, full name and model, motherboard model, product number,etc.
post the contents of the bios chip even if it is corrupted..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Add fail old bios.
I flashed a clean bios - the laptop worked.
But I can't find dmi with my data. I found the windows key - A9E010
I wanted to restore the original sn, pn, build_id and future_byte, but I can't find them)Attached FilesComment
Good day
Please HELP with ec bios .
I have tried a clean bios from hp, but unit still doesn't display just restarts none stop.
I have uploaded both files EC and MAIN
HP Pavilion x360 convertible model 14-dw0028ns
SN/ 5CG0480DTZ
FAULT / NO DISPLAYAttached FilesComment
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
