Razer Blade 15” Base 2020 (RZ09-0328x) Bricked due to BIOS upgrade
  • matusiq
    • Dec 2020
    • 58
    • Slovakia
    Re: Razer Blade 15” Base 2020 (RZ09-0328x) Bricked due to BIOS upgrade
    What about your first BACKUP dump ... that was working ,, you still got it ?? For EC BIOS (ENE,ITE chip ... google it what are u looking on your motherboard) you need special programmer, but not always as some EC chip dont need to be programmed...
    I would imagine that the laptop is still under warranty ?? I would say that the problem is somewhere else ... have u measured any voltages on BIOS chip leg 8 ??
    • beatngu
      • May 2021
      • 21
      • Sweden
      Sorry for the late reply... I don't have any first backup as didn't think an official BIOS update can mess things up like this (now I've learnt for my entire life...).
      I will measure the voltage tomorrow.
      It still has warranty but I bought it on ebay from a "non-authorized" seller hence Razer doesn't accept it. So they would repair it for a fee and what I've learnt so far from other forums that would be a whole motherboard replacement which will cost a lot...
      I suspect the EC as a route cause as the machine went down completely when I installed an EC upgrade which was not for my machine (good question why the installer let it happen). But this was my mistake.
      • matusiq
        • Dec 2020
        • 58
        • Slovakia
        I dont know what type of programmer are you using but the clip is not always 100% good kit to use. The another chip you said that you can not recognize ...read with clip because the legs could be connected somewhere else and it has to be removed to do proper reading.
        I would still say that the problem could be in BIOS ...
        • simon6369
          • Jun 2021
          Are there some News ? I ve got the same problem. Bought the device from Razer. They wont give me warranty because of some e-cigarette liquid in the fans. But the problem appeared right after the BIOS Update reboot.
          • simon6369
            • Jun 2021
            I just did it ! !!!! I flashed it kind of 100 times. But i now got a flasher which worked. Fck you razer support. Take the 1.06.bin and use the ch341a 1.4 .
            Ive got the same symptomatic as you got. Ive uploaded you the program. Hope it helps anybody out there. It was so frustrating. Razer wanted 1350 € for repair. No spare parts out there. Nothing near a good support. They even couldnt send me the bios files.
            • simon6369
              • Jun 2021
              i ve got a solution
              • beatngu
                • May 2021
                • 21
                • Sweden
                #27
                I've also tried it so many times and even if programmer says flashing was successful I still can't turn on my machine, no leds flashing, etc. Any more ideas? That repair cost you mentioned worries me so much...:O
                • beatngu
                  • May 2021
                  • 21
                  • Sweden
                  #28
                  Do you think ordering a new BIOS chip from ebay and soldering it would help solving it?
                  • beatngu
                    • May 2021
                    • 21
                    • Sweden
                    #29
                    I found this: https://www.ebay.com/itm/133816876844
                    ...which seems to be the one for my machine.
                    • beatngu
                      • May 2021
                      • 21
                      • Sweden
                      #30
                      I've talked to a guy who mentioned that this model has two BIOS chips. I've made a screenshot (attached):
                      The main one is Winbond 25Q128FV (marked as red) and that contains that 16 MB bios which I could manage to flash.
                      But the problem would be with the second one (Gigadevice GD25Q64CSIG, marked as blue) which holds EC FW. So if I would have the image for this secondary device and flash it that would help I guess.
                      So my question is if anyone has similar model / motherboard would it be possible to extract it and send it to me? Or would you suggest in which other thread should I request it?
                      Thanks!
                        • 22191
                        Thanks!
                        Post the GD25Q64CSIG backup,even if corrupt, and also post the WRONG EC updater ,to check if contents are the same .
                        • beatngu
                          • May 2021
                          • 21
                          • Sweden
                          #32
                          Will try to get that and will get back to you. Thanks.
                          • beatngu
                            • May 2021
                            • 21
                            • Sweden
                            #33
                            So I could manage the attached image from this secondary BIOS. What I can understand that it holds this EC FW which has version 1.0. Could this cause the whole issue with my machine?
                              • 22191
                              It does have EC firmware,the problem is the filesize is 16MB ,the GD25Q64CSIG is an 8MB chip, so i can only guess that youve chosen the wrong chip in your programmer software and its read the chip twice to make a 16MB file.I split it into two 8MB and the files are identical.The EC has your DMI info in it,serial and win key. Which EC did you flash,what was the bios updater you used,from which model ? , have you still got the file you flashed that bricked it ?
                              There`s no EC update available at the razer support for the RZ09-0328x ,i guess they never released one. So,you`d need an EC dump from the same model. Get in touch again with razer and ask them if they can provide one
                              • beatngu
                                • May 2021
                                • 21
                                • Sweden
                                #35
                                Could you please send me divided (8MB file)?
                                I already asked Razer "support" million times but they keep saying they don't send individual parts and I should send it back to them for repair (which means a full mobo replace most probably...
                                  • 22191
                                  8MB EC attached. You will still need an EC dump though, if it has been flashed with the wrong one.If someone posts one then its a quick job to copy your DMI from the old one to the new one.
                                    • 22191
                                    They don`t need to send you the chip, just a download link to the EC firmware .
                                    • beatngu
                                      • May 2021
                                      • 21
                                      • Sweden
                                      #38
                                      Yeah, I described that at least 3 times to them but those "professional" retards doesn't seem to be getting what I ask for (or don't want to help).
                                      • minhduc18
                                        • Mar 2021
                                        • 32
                                        • viet nam
                                        #39
                                        i have Razer 2020 RZ09-03287E22 no display, i need bios,please help me!
                                          • 22191
                                          Bios .
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • vinaypundith
                                            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                            by vinaypundith
                                            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                            So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                            08-03-2024, 12:32 PM
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • Awdev
                                            Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
                                            by Awdev
                                            S/N is BY2011A72401766
                                            Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
                                            MB Model is: DA530-MB
                                            Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
                                            10-18-2025, 02:13 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
