Razer Blade 15” Base 2020 (RZ09-0328x) Bricked due to BIOS upgrade
  • beatngu
    • May 2021
    • 21
    • Sweden
    Hello Guys,
    I have a Razer Blade 15” Base 2020 (RZ09-0328x) and performed a BIOS update last week (used the factory 1.06). During installation Windows 10 BSODd and my computer didn't start anymore. I could manage to manually flash the BIOS with a CH341A Programmer (only to version 1.03 as 1.06 is still killing my machine) but after that my touchpad is not working anymore. When I check BIOS I could see proper main version but for EC FW and MCU FW versions I see version 1.0.x. (which seems to be incorrect for me). I extracted the BIOS image from official updater (it contained 2 BINs, Dana5_0106.bin and Dana5_0106_FWUpdate.bin.
    After few more attmepts my laptop totally died (no charging, no LEDs, etc.). I guess it has something to do with EC chip.
    So my request would be if anyone has the same model would you please provide me extracted BIOS and EC FW?
    Thanks much in advance!
  • peste
    • 13350
    • ROMANIA
    Re: Razer Blade 15” Base 2020 (RZ09-0328x) Bricked due to BIOS upgrade
    Originally posted by beatngu
    Hello Guys,
    post the original backup of the main and EC bios laptop.
    • beatngu
      • May 2021
      • 21
      • Sweden
      Hi and thanks for your reply! The main bios backup is the same as the original one but for EC i don't have any. I should try to extract the current EC but i guess that would be a broken one.
      Anything else I can try to provide?
      • beatngu
        • May 2021
        • 21
        • Sweden
        • matusiq
          • Dec 2020
          • 58
          • Slovakia
          Have you used the clip or desoldering the chip ?? Make sure it it soldered properly ...
          • beatngu
            • May 2021
            • 21
            • Sweden
            I used the clip. I think the main BIOS should be fine as I could manage to flash it successfully but the issue is with EC. And I couldn't find EC FW for my model (Razer "support" doesn't provide either).
            • matusiq
              • Dec 2020
              • 58
              • Slovakia
              Have you located another spi chip there for EC Bios or you have just one ?? What KBC You have over there ?? ITE, ENE ... take a picture of it ... ,, plug it the charger and measure the voltage on BIOS chip leg 8 ... should be 3,3V
                • 21606
                The Dana5_0106_FWUpdate.bin isn`t EC firmware,its ME firmware .
                • beatngu
                  • May 2021
                  • 21
                  • Sweden
                  I will check and let you know. Thanks!
                  • beatngu
                    • May 2021
                    • 21
                    • Sweden
                    Thanks! I remember once the windows was working I could manage to run Razer BIOS installed 1.06 which contained this FW but when I checked in BIOS, the ME version was still 1.0.0. (which I guess not updated).
                      • 21606
                      Program the Dana5_0106.bin again, use NeoProgrammer software. The ch341a (using ch341a software) can fool you sometimes saying its flashed and verified when it hasnt done anything. The bios has configured ME firmware so its AOK.
                      https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                      • beatngu
                        • May 2021
                        • 21
                        • Sweden
                        I've done that again (exactly same steps what you wrote) but my machine is still not turning on. Adding some screenshots of the process.
                        • beatngu
                          • May 2021
                          • 21
                          • Sweden
                          I'm not sure which chip should be the EC one. Made a screenshot and marked BIOS chip with RED. Probably EC is the one marked with BLUE?
                          It's so tough to read what's been written on the chips. Any more details what I'm looking for?
                            • 21606
                            Some boards won`t boot unless the screen is connected. Remove the charger and battery ,connect the cmos battery if there is one ,then the screen,keyboard,battery ,then the charger and try it
                            • beatngu
                              • May 2021
                              • 21
                              • Sweden
                              Thanks. Removed and reconnected everything but no luck.
                                • 21606
                                Have you put the clip on that one marked blue,it looks like a resistor or cap may be missing,i can`t really tell. If you have a microscope or magnifier take a close up image, and read the part number from the chip as well.
                                • beatngu
                                  • May 2021
                                  • 21
                                  • Sweden
                                  Probably few missed letters but BLUE chip should be GD25Q64CSIGTR.
                                    • 21606
                                    Not sure what could be on that, maybe the thunderbolt firmware
                                    • matusiq
                                      • Dec 2020
                                      • 58
                                      • Slovakia
                                      Chip marked with RED ... sure that it is the right position ??? I can see that have been removed ... maku sure the legs are soldered good ...
                                      • beatngu
                                        • May 2021
                                        • 21
                                        • Sweden
                                        I haven't removed it during flash. I used a clip. And I could manage to re-flash it today successfully.
                                        I remember when the issue was only with main bios I could see LEDs working. But not anymore. I guess that would be due to EC? I found another chipset (also from WINBOUND) close to the area where keyboard connects to motherboard. Programmer also identified it but could not retrieve image as - I guess - it's broken. So would be nice to find someone who has the same model and could provide EC FW.
                                        • vinaypundith
                                          Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                                          by vinaypundith
                                          I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                                          So, I'm looking for a BIOS dump for this machine - a 16MB one....
                                          08-03-2024, 12:32 PM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • DavidChunco
                                          Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                                          by DavidChunco
                                          Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                                          - Receive help from Dell Support (it is out of warranty).
                                          - Disconnect machine from AC power and battery overnight.
                                          - BIOS recovery process
                                          - Connected external display via HDMI
                                          - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                                          03-15-2025, 11:00 AM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
