NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
I've got a few 840 G5 laptops in the shop, all of them have simmilar problems, here are the dumps from one of them from both chips , I've tried the dump from few posts above, but only get caps lock turned on....
S/N 5CG8515SSC
model 840 G5
Board number 6050A3022501-MB-A01Attached FilesComment
Dear Blaze Tech and others
I broke my W25Q256JV bios (phisically) from HP EliteBook 840 G5 6050a2945601-mb-a01
May I ask for BIOS for serial number 5CG013DSCM ProdID 2FA66AV please?
I tried adjust bios bymyself to change Serial Number with HEX but still I have issue CPU fan spins at maximum speed.Last edited by Karol Wu; 05-15-2025, 03:48 AM.Comment
hello everyone, mistakenly i have read the main bios instead EC chip. now my laptop is working but keyboard is not working properly i think because of the main bios corruption. can someone send me the original main bios file for W25Q256JVEQ chip? in this model EC chip is located under the motherboard which is 128MB chip. in 256MB does not include security things like bios passwords and all. bios password i removed successfully from the 128MB chip by searching active on hxd file but after that also keyboard is not working properly and when i use with bios password it worked very well.i tried to reprogram with the backup that i mistakenly read for 256MB but the issue still appears. maybe i have not read it properly. unfortunately here i can not upload the attachments it says i am not allowed to attach bin file extensions. S/N 5CG922701G PROD ID 2FA66AV. i connected external usb keyboard also but issue persisits. please help me with it. thanksComment
post full name and model, motherboard model,Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
S/N 5CG922701G
SYS. BOARD ID 83B2
M/B L15518-601Attached FilesComment
I need new bios
Is it requires to flash also second 16MB bios as well?
Thank youComment
hp elitebook 840 g5
S/N 5CG9314BT2
prodID 7JQ98UC#ABA
computro-6050a2945601
laptop comes on no display no backlight , few secaonds later cpu fan comes on
attatched backup of main bios and ec bios
any help will be appriciated
thankyouAttached FilesComment
this bios with no sound and laptop isnt work good i hope ou can guys can makes new bios it have intel i5 8th
hp elitebook 840 g5
serial number 5cg8470zjt
For those who need a clean BIOS (no passwords, factory defaults, without DMI) for the HP EliteBook 840 G5 (6050A2945601-MB-A01):
Since nobody here could help me, I turned to Wrong Chip on YouTube (link below). Here's my experience for others facing similar issues:- These BIOS files work—I successfully flashed both by CH341A (modded from 5V for 3.3V!) by Neoprogrammer on Windows:
- 32MB chip (W25Q256JVEIQ)
- 16MB chip (W25Q128JVPQ)
- My W25Q256JVEIQ BIOS was corrupted (physical damagel). You can use my files, but they do NOT include DMI data (you have mine attached for serial 5CG013DSCM)
- DMI Solution: Wrong Chip provided my DMI data, which I injected using the method shown in this video:
- HP Manufacturing Program Mode | WHY it Happens & How to LOCK it
https://www.youtube.com/watch?v=ucZ-nn1aEt0
- Boot Failure? Another reason my laptop wouldn't turn on was accidentally removing the 22-ohm resistor. If your motherboard is unresponsive, double-check all resistors!
Re: NEED BIOS FOR HP EliteBook 840 G6
SN: 5CG9387SSY
mb MODEL 6050a2945601-mb-a01
SIR HELP ME PLEASE
NO DISPLAY PROBLEM
EC FILE OTHER ENGINNER CHANGE, I DONT KNOW ITS ORGINAL OR NOT
MAIN FILE ORGINAL FILE
I ATTCHED MY FILE
I WRITE MANY MAIN FILE, BUT FAN FULL SPEED & NO DISPLAY
My DMI if you don't have yours you can try as above YouTube movie after start
Serial Number: "5CG013DSCM" SKU Number: "2FA66AV"
Board CT Number: "PGWHT00WBDH1KY"
Product Name: "HP EliteBook 840 G5"
BuildID: "17WWCSDT601#SABD#DABD"
Feature Byte: "3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXhKhkjh.fm"
MAC Address: "10-62-E5-56-A7-0D"
SN: 5CG9387SSY
SIR HELP ME PLEASE
NO DISPLAY PROBLEM
I ATTCHED MY FILE
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
