NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
  • rex98
    • Feb 2023
    • 1287
    • Mandaue CEBU, Philippines
    #301
    here flash both. and you need to input your original DMI data, use BCU.
    • baiceanu_stefan
      • Feb 2015
      • 39
      #302
      Hello, thx for your reply. With the files you provided the laptop is not powering on at all - only power led near the jack blinks continous. nothing else.
      • Bonzas
        • 472
        • Indonesia
        #303
        is this possible build full bios and ec from hp site ? i got board with blank chip both ec & main. i already try some bios from previous page, get 1 bios that work but late display. already try to build with latest Q78, clean it but no luck. this bios take 1+ minute to display.
        Maybe someone can help try this bios or help repair it
        • danel2210
          • Dec 2018
          • 12
          • philippines
          #304
          pls help me clean bios of
          HP 840 G5 computro 605012945601 mb-a01​
          sn# 5cg82906fr
          • bomdespacho
            • Nov 2023
            • Brasil
            #305
            so testar
            • 7martinsk7
              • Nov 2017
              • Slovakia
              #306
              Hello, I have a 2FA56AV (i7 8550U + AMD RX 540) with bricked bios (no image, 5x CapsLock LED). I have since flashed different BIOS (both 16 and 32M) but the AMD GPU and touchscreen are not detected by Windows nor BIOS menu.
              Can somebody please repair my original BIOS or provide working one from the same model so all the components work properly?
              I cant find the proper bios anywhere.
              SN: 5CG9287RC4
              • 7martinsk7
                • Nov 2017
                • Slovakia
                #307
                Okay so I fixed my BIOS by replacing the first half of the 32M file with data from another BIOS downloaded from the net. This way the GPU is detected and everything works properly.
                I found out there is no touch on my laptop, the screen was probably replaced with no touch one.
                I am including both 16M and 32M dump files that work and also support the AMD GPU. It should work on models 2FA50AV, 2FA52AV, 2FA54AV, 2FA56AV and 2FA58AV.
                I have also cleaned the ME region for others to use, but did not verify if it is working.
                • Bonzas
                  • 472
                  • Indonesia
                  #308
                  Originally posted by bomdespacho
                  so testar
                  I can't test your file right now, my customer took laptop cause she will use it for school until next week. i'll try if my customer back to my workshop. But thank for for file
                  • Seroygin
                    • Nov 2023
                    • Украина
                    #309
                    SN: 5CG9287RC4
                    Hi. I had a similar situation with the touchscreen. It did not work until I added all the information, serial numbers, feature byte from the sticker on the back of the cover. This can be done when the bios is in engineering mode, or with HP BIOS Configuration Utility (BCU)
                    • Hachem25
                      • Aug 2021
                      • 45
                      • algeria
                      #310
                      hello. i have this hp elitebook 840 g5 . when it comes on there is no display and after a while the spines at max. if someone can help me.
                      SN: 5CG82426FZ
                      ProdId: 3YH22UC#ABA
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12118
                        #311
                        SN: 5CG82426FZ
                        ProdId: 3YH22UC#ABA
                        HP EliteBook 840 G5 Notebook PC
                        • danel2210
                          • Dec 2018
                          • 12
                          • philippines
                          #312
                          Pls help me rebuild this bios
                          S/N 5cg90964m2
                          • danito
                            • Jun 2016
                            • 1049
                            #313
                            S/N 5cg90964m2
                            what's the problem?
                            • danel2210
                              • Dec 2018
                              • 12
                              • philippines
                              #314
                              Originally posted by danito
                              what's the problem?
                              power loop only sir
                              • danito
                                • Jun 2016
                                • 1049
                                #315
                                power loop only sir
                                try
                                • Nadeem Amin
                                  • Dec 2014
                                  • 33
                                  • pakistan
                                  #316
                                  HP 840-G5 NO DISPLEY ISSUE
                                  I hv another file from this platform..now laptop hv late displey issue and tow more erors.
                                  can anybody fix my old backup file which hv no displey..ihv attached the3 file and part no. and sn no.
                                  THANKS.
                                  • Technosoft
                                    Absolute Noob
                                    • Jul 2023
                                    • 7
                                    • The worlds backyard
                                    #317
                                    Need help, I have Hp 840 G5, no display, fan goes in max Bios Chip: MX25L25673GZ41-08
                                    • Blaze Tech
                                      Learner
                                      • 212
                                      • Ghana
                                      #318
                                      TRY
                                      • Eric assenga
                                        • Jan 2023
                                        • 31
                                        • Tanzania
                                        #319
                                        SOMEONE help to do me clean for hp elitebook 840 g5 computro 6050a2945601 mb a01
                                        SN 5CG9200WK3
                                          SMDFlea commented
                                          Editing a comment
                                          Thread merged with existing topic.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12118
                                        #320
                                        Originally posted by tiagofernandes
                                        Sorry 850 g5
                                        SN:5cg9084t70
                                        Thx
                                        HP EliteBook 850 G5 Notebook PC
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
