x512ja r2.0 dump bios
  • pokyss1
    • Mar 2019
    • 58
    • TUNISE
    x512ja r2.0
  • peste
    • Dec 2016
    • 12859
    • ROMANIA
    Re: x512ja r2.0 dump bios
    Originally posted by pokyss1
    x512ja r2.0
    post the backup of the bios, and pictures with the white or green stickers on the motherboard.
    • pokyss1
      • Mar 2019
      • 58
      • TUNISE
      I don't have the bios backup.
      I deleted by mistake.
      and I have already posted an image of the map.
      thank you
      • peste
        • Dec 2016
        • 12859
        • ROMANIA
        j ai pas le sauvegarde du bios .
        j ai supprime par erreur .
        et j ai déjà poste une image de la carte .
        merci
        I'm talking about the stickers on the memory slots ram ... in English please ..
        • pokyss1
          • Mar 2019
          • 58
          • TUNISE
          https://****************/dump/kompju...424-1-0-101829
          I need this file if it is possible sea and sorry for my anglaisit is not good
          • rager007
            • Feb 2016
            • 106
            • Usa
            Bios start ok no screen 1.00 amper
            board model x512ja R2.0 Case: x512j
            Repair please THX..
            • Mazorca
              • Jan 2017
              • 463
              Try this file, Bios region from website, ME region from repositories and your own DMI (I hope I got it right).
              • rager007
                • Feb 2016
                • 106
                • Usa
                hii thx the bios you repaired didn't happen
                I sent corrupt bios ..no screen, current bios
                web site new bios no bin file
                  • 20977
                  Post a good clear picture of the square white QR code ,its just above the "X512JA MAIN BOARD" silkscreen
                  • rager007
                    • Feb 2016
                    • 106
                    • Usa
                    thank you
                      • 20977
                      thank you
                      On the motherboard ! like the one at post #1
                      • rager007
                        • Feb 2016
                        • 106
                        • Usa
                        ok
                          • 20977
                          ok
                          Try this one .I think the QR sticker says X512JF ,its a bit blurred the printing is a bit off.
                          • rager007
                            • Feb 2016
                            • 106
                            • Usa
                            Thank you yes qr code X512JF
                            I wrote no image // 0.95 * 0.96 draws amps unfortunately it didn't happen
                              • 20977
                              Try writing the bios with Quad enabled. QE=1 .Does your programmer support setting the QE bit
                              • rager007
                                • Feb 2016
                                • 106
                                • Usa
                                minipro 866cs
                                  • 20977
                                  minipro 866cs
                                  The 2nd picture QE9 is enabled.If it doesnt work after that maybe the problem isn`t with the bios ?
                                  • abbassink
                                    • Aug 2015
                                    • 83
                                    • iran
                                    Repair please THX..
                                    i tested . this bios is ok
                                    • issa
                                      • Sep 2022
                                      • ghana
                                      Re: Asus x512uf rev 2.0 bios bin please
                                      asus x512ja rev 2.0 please i need firmware
                                      • cacla
                                        • Apr 2015
                                        • 442
                                        thank you
                                        By this sn this is your bios
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • cekcons
                                          g1 assassin Rev 1 bios dump - main and backup needed
                                          by cekcons
                                          main and backup ic dead so i cant post corrupt bios cause its 01 all over.
                                          thanks
                                          01-23-2024, 03:26 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
