x512ja r2.0 dump bios
  • pokyss1
    • Mar 2019
    • 58
    • TUNISE
    x512ja r2.0
  • peste
    • Dec 2016
    • 13223
    • ROMANIA
    Re: x512ja r2.0 dump bios
    Originally posted by pokyss1
    x512ja r2.0
    post the backup of the bios, and pictures with the white or green stickers on the motherboard.
    • pokyss1
      • Mar 2019
      • 58
      • TUNISE
      I don't have the bios backup.
      I deleted by mistake.
      and I have already posted an image of the map.
      thank you
      • peste
        • Dec 2016
        • 13223
        • ROMANIA
        j ai pas le sauvegarde du bios .
        j ai supprime par erreur .
        et j ai dƩjƠ poste une image de la carte .
        merci
        I'm talking about the stickers on the memory slots ram ... in English please ..
        • pokyss1
          • Mar 2019
          • 58
          • TUNISE
          https://****************/dump/kompju...424-1-0-101829
          I need this file if it is possible sea and sorry for my anglaisit is not good
          • rager007
            • Feb 2016
            • 106
            • Usa
            Bios start ok no screen 1.00 amper
            board model x512ja R2.0 Case: x512j
            Repair please THX..
            • Mazorca
              • Jan 2017
              • 463
              Try this file, Bios region from website, ME region from repositories and your own DMI (I hope I got it right).
              • rager007
                • Feb 2016
                • 106
                • Usa
                hii thx the bios you repaired didn't happen
                I sent corrupt bios ..no screen, current bios
                web site new bios no bin file
                  • 21497
                  Post a good clear picture of the square white QR code ,its just above the "X512JA MAIN BOARD" silkscreen
                  • rager007
                    • Feb 2016
                    • 106
                    • Usa
                    thank you
                      • 21497
                      thank you
                      On the motherboard ! like the one at post #1
                      • rager007
                        • Feb 2016
                        • 106
                        • Usa
                        ok
                          • 21497
                          ok
                          Try this one .I think the QR sticker says X512JF ,its a bit blurred the printing is a bit off.
                          • rager007
                            • Feb 2016
                            • 106
                            • Usa
                            Thank you yes qr code X512JF
                            I wrote no image // 0.95 * 0.96 draws amps unfortunately it didn't happen
                              • 21497
                              Try writing the bios with Quad enabled. QE=1 .Does your programmer support setting the QE bit
                              • rager007
                                • Feb 2016
                                • 106
                                • Usa
                                minipro 866cs
                                  • 21497
                                  minipro 866cs
                                  The 2nd picture QE9 is enabled.If it doesnt work after that maybe the problem isn`t with the bios ?
                                  • abbassink
                                    • Aug 2015
                                    • 83
                                    • iran
                                    Repair please THX..
                                    i tested . this bios is ok
                                    • issa
                                      • Sep 2022
                                      • ghana
                                      Re: Asus x512uf rev 2.0 bios bin please
                                      asus x512ja rev 2.0 please i need firmware
                                      • cacla
                                        • Apr 2015
                                        • 442
                                        thank you
                                        By this sn this is your bios
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers šŸ˜€,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
                                          šŸ”§ Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          šŸ’€ Problem:šŸ˜…
                                          - Device shows ā€œAdministrator Passwordā€...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • greelidd
                                          K6604J Vivobook RTX 4070 BIOS Dump Request
                                          by greelidd
                                          Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                                          Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                                          09-01-2025, 06:14 PM
                                        • cekcons
                                          g1 assassin Rev 1 bios dump - main and backup needed
                                          by cekcons
                                          main and backup ic dead so i cant post corrupt bios cause its 01 all over.
                                          thanks
                                          01-23-2024, 03:26 AM
