Clean me for Hpprobook 430 g2.
  • Gudguy
    • Jun 2016
    • 48
    • Nigeria
    friends, i need clean me for this bios file hp probook 430 g2.thanks for your help
  • lapfix
    • Mar 2020
    • 2719
    • my workshop
    Re: Clean me for Hpprobook 430 g2.
    Post your old dump
    • Gudguy
      • Jun 2016
      • 48
      • Nigeria
      • lapfix
        • Mar 2020
        • 2719
        • my workshop
        i ve got error with your dump , can you try another one
        • Gudguy
          • Jun 2016
          • 48
          • Nigeria
          here attach d bin file
            • 20763
            Try this one .
              • 20763
              Was the error about a VSCC entry
              • lapfix
                • Mar 2020
                • 2719
                • my workshop
                Yes
                  • 20763
                  Yes
                  You can remove the problematic VSCC Device 10 ,you can right click on it and select "Remove Table Entry"
                  • lapfix
                    • Mar 2020
                    • 2719
                    • my workshop
                    Thank you Smdflea, why n10! not one of the others !!
                      • 20763
                      When you try and build the image it will give an error message about VSCC Device 10 no historic VSCC ,and it will fail to build the outimage.bin .After you remove the table entry it will build ok.
                      • okbalord
                        • Jun 2017
                        • 204
                        • Algeria
                        Try this one .
                        ty work fine
                        OKBALORD
                        • studdy05
                          Bricked HP Probook 450 G7 Bios questions
                          by studdy05
                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                          Ive got...
                          07-08-2025, 09:24 PM
                        • Forest79
                          by Forest79
                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                          07-23-2023, 07:39 AM
                        • maanee11
                          Help to get Lenovo BIOS bin file for Thinkpad T560
                          by maanee11
                          Hello Everyone,
                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                          05-15-2022, 11:59 AM
                        • Sebastian Codrean
                          BIOS file for ASUS F542UN laptop
                          by Sebastian Codrean
                          Hello to all of you! I need help with a BIOS file.
                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                          02-20-2025, 10:25 AM
                        • Fr33man
                          BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                          by Fr33man
                          I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                          *Novo button power on
                          *Disconnected internal battery...
                          09-23-2024, 01:16 PM
