Need a bin file for a HP 15-cr0011nr
  • mmicrosysm
    • Aug 2006
    • 4
    Looking for a bin file for a HP Pavilion x360 15-cr0011nr, the one supplied by HP is too big for some reason
    Should be 8,192k but is 8,963k so not sure what gives with their file. Either way it's not usable as it bigger then the chip size.
    Thank You
    • 20781
    Re: Need a bin file for a HP 15-cr0011nr
    Thank You
    Run the bios update from the support site,it will give you the option to make a recovery key or make a copy.If you choose copy the saved file will be 8,192KB .
    If you flash that bios you will lose DMI info ,serial etc. If you want your DMI adding make a backup of your original bios and post it here in a zip or rar.
    • mmicrosysm
      • Aug 2006
      • 4
      Okay, thanks
      https://mmicrosysm.net//downloads/HP%20BIOS%20ROM.zip original bios file marked ORG
      • mmicrosysm
        • Aug 2006
        • 4
        Was I supposed to post elsewhere for the DMI inject?
          • 20781
          here
          • mmicrosysm
            • Aug 2006
            • 4
            here
            Thank you sir.
            • Forest79
              by Forest79
              However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
              07-23-2023, 07:39 AM
            • maanee11
              Help to get Lenovo BIOS bin file for Thinkpad T560
              by maanee11
              Hello Everyone,
              I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
              https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
              In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
              05-15-2022, 11:59 AM
            • Sebastian Codrean
              BIOS file for ASUS F542UN laptop
              by Sebastian Codrean
              Hello to all of you! I need help with a BIOS file.
              The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
              So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
              02-20-2025, 10:25 AM
            • Fr33man
              BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
              by Fr33man
              I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
              *Novo button power on
              *Disconnected internal battery...
              09-23-2024, 01:16 PM
            • iZakre
              HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
              by iZakre
              Hello everybody!
              To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
              The thing is that I had installed TeamViewer and could log into the computer...
              02-19-2023, 02:27 PM
