Need a bin file for a HP 15-cr0011nr
  • mmicrosysm
    • Aug 2006
    Looking for a bin file for a HP Pavilion x360 15-cr0011nr, the one supplied by HP is too big for some reason
    Should be 8,192k but is 8,963k so not sure what gives with their file. Either way it's not usable as it bigger then the chip size.
    Thank You
    • 22275
    Re: Need a bin file for a HP 15-cr0011nr
    Thank You
    Run the bios update from the support site,it will give you the option to make a recovery key or make a copy.If you choose copy the saved file will be 8,192KB .
    If you flash that bios you will lose DMI info ,serial etc. If you want your DMI adding make a backup of your original bios and post it here in a zip or rar.
    • mmicrosysm
      • Aug 2006
      Okay, thanks
      https://mmicrosysm.net//downloads/HP%20BIOS%20ROM.zip original bios file marked ORG
      • mmicrosysm
        • Aug 2006
        Was I supposed to post elsewhere for the DMI inject?
          • 22275
          here
          • mmicrosysm
            • Aug 2006
            here
            Thank you sir.
            • to5it0
              by to5it0
              10-24-2025, 01:35 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • maanee11
              Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
              by maanee11
              Hello Everyone,
              I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
              It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
              In the website, you can only see specs etc.
              I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
              11-08-2025, 04:08 AM
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • Forest79
              by Forest79
              07-23-2023, 07:39 AM
