Hp 255 g4
  • steven_k
    • Apr 2021
    • 4
    • Greece
    Hp 255 g4
    I have an issue with my HP 255 G4. Without having replaced the motherboard i get the following error message:
    "Product Information not valid - The Following product information programmed into system board is missing or invalid
    System board (00A) Product Name, Product Serial Number, Product Number and System Board CT Number".
    When enter the bios i see born up date and factory installed os is missing too. I tried HP BCU and after enter all values and when i typed the command "/SetConfig :"filename" i got an Access Denied error.
    • 22276
    Re: Hp 255 g4
    Post your bios backup, its probably corrupt.
    • steven_k
      • Apr 2021
      • 4
      • Greece
      Re: Hp 255 g4
      Thanks, for your reply! I haven't backup my bios before its corruption. I have tried with the universal bios backup toolkit 2.0 and i got an error "Can not Identify the BIOS!". Is there anything else i can try?
      • huss584
        Hussein
        • Apr 2020
        • 234
        • Palestine
        Re: Hp 255 g4
        Please Clean my BIOS
        Attached BIOS
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          Re: Hp 255 g4
          Attached BIOS
          This file has no ME region to clean.
          ​https://www.badcaps.net/donate
          • huss584
            Hussein
            • Apr 2020
            • 234
            • Palestine
            Re: Hp 255 g4
            Originally posted by hoaca388
            this file has no me region to clean.
            sn: Cnd6241ckb
            • huss584
              Hussein
              • Apr 2020
              • 234
              • Palestine
              Re: Hp 255 g4
              thankls it working for me
              • aahilkhan43
                • Feb 2020
                • 42
                HP 255 G4
                ABL51 LA-C781P
                Bios need to repair.
                please help me to repair.
                thanks.
                • peste
                  peste commented
                  Editing a comment
                  post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
              • peste
                • Dec 2016
                • 13924
                • ROMANIA
                Originally posted by aahilkhan43
                HP 255 G4
                ABL51 LA-C781P
                thanks.
                post S/N, product number,etc.
                • aahilkhan43
                  • Feb 2020
                  • 42
                  sorry im not use to here. next time I'll, thanks
                  SNO: CND5434975
                  • BMCappelletti
                    Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                    by BMCappelletti
                    Hi everyone.
                    Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                    Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                    Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                    02-18-2025, 12:22 PM
                  • ugamazing
                    820-02020 PPBUS_AON missing
                    by ugamazing
                    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                    02-05-2025, 04:21 PM
                  • jpreza
                    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                    by jpreza
                    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                    Looking at the card, it appears to be missing the following:
                    1x 1.0uH inductor - orange square
                    2x...
                    11-01-2024, 10:54 PM
                  • eltano4i20
                    [HELP] SAMSUNG NP270E4E-K01AR
                    by eltano4i20
                    1) Error trying to enter the BIOS
                    --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                    Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                    BOOT PRIORITY ORDER (img-05)
                    1- Windows Boot Manager
                    2- SATA HDD
                    3- NETWORK
                    4- Debian
                    2) Error trying to access the BOOT MENU
                    --> I restarted the notebook and pressed [F10] but the BOOT...
                    07-04-2025, 12:39 AM
                  • BYTEHAT248
                    Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                    by BYTEHAT248
                    Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                    11-14-2025, 04:48 PM
