HP 17-AB04ND bios clearn me or new one
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    i need bios for HP 17-AB04ND. i have attached the old dump if it be repaired for me.
    • 20950
    Re: HP 17-AB04ND bios clearn me or new one
    17-ab040nd
      • 20950
      Go to the support site,enter the serial number,then download the bios. https://support.hp.com/gb-en/drivers...62?sku=X8P25EA .Run the exe,it will give you the option to make a recovery key.If running the recovery key doesn`t work run the exe again and select the copy option (or copy the bios from the recovery key) .There are 3 different bios to choose from, so open your bios backup with a hex editor to find out which one you need.Use the hex editors text search, and use the keyword BID or each bios name.
      HxD hex editor: https://mh-nexus.de/en/hxd/
      Search for the serial number using the text search, 5CD6334YXG .Copy the DMI information from 6AC000 - 6AE0FF to the virgin bios, and copy the win key from 278000 - 27803F to the virgin bios.
      • jacospama
        • Aug 2019
        • 240
        • Ghana
        Thank you Senior. please i couldnt so if can give me the step by step tutorial
        • jendkkd jeje
          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
          by jendkkd jeje
          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
          10-11-2024, 03:12 PM
        • Caimano
          Need to copy DMI info for HP ProBook 650 G2 Bios
          by Caimano
          UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
          Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
          01-03-2024, 05:19 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • ikelectro
          After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
          by ikelectro
          Schematic : DAOP5EMB6E0 REV:E​
          I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
          Any help or guide to proceed?...
          03-19-2025, 08:17 PM
