HP EliteBook 8740w nonVPRO bios dump need
  • Thunder1986
    • Feb 2015
    • 25
    • Hungary
    I have a nonVPRO motherboard whose BIOS has crashed during a motherboard repair. I found a BIOS here but the VPRO descriptor is locked. I can't switch because of this. I would need a nonVPRO or a completely virgin BIOS dump. I want this because the fan is currently running at full speed.
    Thank you!
  • Thunder1986
    • Feb 2015
    • 25
    • Hungary
    Re: HP EliteBook 8740w nonVPRO bios dump need
    I finally solved it. I put the old BIOS dump ME firmware into the new working BIOS dump. And the fan operation has improved
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
