Pliss HELP BIOS PANASONIC CF-S9
  • heriyanto39
    • Jul 2020
    • 4
    • Indonesia
    pliss bios panasonic CF-S9
    my bios locked pasword
  • heriyanto39
    • Jul 2020
    • 4
    • Indonesia
    Re: Pliss HELP BIOS PANASONIC CF-S9
    my bios locked
    • peste
      • Dec 2016
      • 12652
      • ROMANIA
      Originally posted by heriyanto39
      my bios locked
      try..
      • heriyanto39
        • Jul 2020
        • 4
        • Indonesia
        Originally posted by peste
        try..
        its working thanks my brother
        • AquaMan Ua
          by AquaMan Ua
          05-17-2025, 09:40 AM
        • aa10aa10
          Panasonic Toughbook CF-33 mk1 BIOS repair
          by aa10aa10
          Good day,
          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
          01-21-2025, 06:13 AM
        • Mnawar27
          Panasonic CF-H2AU24EF3 bios locked
          by Mnawar27
          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
          I need help to remove it,
          thankyou all.
          SN; 2FKCA26876...
          11-16-2024, 08:00 AM
        • dr_crx
          Dell 7740 Bios locked J3JSD43-8FC8
          by dr_crx
          Hello i need help please
          i have DELL 7740 ST: J3JSD43-8FC8
          i tried to read bios bit i think it is wrong because the size of the file is around 1mb
          anyone can help to show its location on motherboard please.
          i attached the results file the IC i read is : winbond 25q80dvsig
          i don't know if its the needed bios or another bios on the motherboard.
          thank you in advanced for your help...
          07-11-2025, 12:22 AM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
