Re: T2 Chip Programmer Tool
Did you save the original ROM Data from the T2 Rom Chip? You may have not programmed it correctly which will again result in it not booting correctly. I know it sounds dumb but it does happen, when you desoldered the chip did you have the battery disconnected and the cable to the battery disconnected? and if you did solder it correctly I would assume you corrupted the chip, sometimes you can heat up the chip to much to where you need to purchase a new one. As long as you have the orginal BIN data you will be fine also keep in mind changing the serial is all thats needed so I do not know why you are DFU restoring the device if you are removing an MDM lock? Just my 2 cents.
