T2 Chip Programmer Tool
This topic is closed.
  • kevingill
    • Jun 2013
    • 152
    • England
    #281
    Re: T2 Chip Programmer Tool
    Originally posted by xploiter
    it is not mdm locked if it is wiped and with activation lock. mdm gets installed during os installation.
    If so, what's the purpose of the option in the Recovery Assistant -> Activate with MDM key?
    • xploiter
      • May 2022
      • 5
      • uk
      #282
      it has to be there for the use cases that require it
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Not true. MDM can still have Activation lock to the company email. Changing the serial will solve this issue and remove the lock for good. Even with iBridge 6+
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • xploiter
          • May 2022
          • 5
          • uk
          #284
          right activation lock is based on email - be it personal or company
          mdm lock is based on user profiles defined by company
          therefore you can't be mdm locked on a wiped computer since there is no os with profiles installed on it.
          if the activation lock email is the company email it doesn't make it a mdm lock.
          • pumemule
            • Feb 2019
            • israel
            #285
            But when i try to install os on mdm lock after serial change it give activation error.
            • curiositymaster
              • Apr 2021
              • 45
              • Nigeria
              #286
              You need to activate your mac before changing serial. If your T2 mac is unactivated and you edit the serial, it won't go past the activation stage.
              • pumemule
                • Feb 2019
                • israel
                #287
                So its one-time solution , in the next reinstall the mac will not be activated...
                • .::iRizwan::.
                  Banned
                  • Apr 2016
                  • 63
                  • Pakistan
                  #288
                  don't do it by changing Serial.
                  do it by bypass method.
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 674
                    Bypass method is not permanent why would anyone want to do that when changing the serial is 100% never coming back even if you DFU restore it?
                    Also to answer the other guy when he changes the serial it gives activation error, this means it's iCloud locked and not MDM lock which means the T2 chip is the culprit, MDM locks do not use the T2 to communicate to verify. It goes like this
                    Apple Server checks in these steps.
                    1. Apple server checks Serial number , if it kicks back as MDM it follows up with two scenarios, you either get into Os Install or you get the company email lock.
                    2. Apple server checks T2 chip serial after step 1. So if step one is a serial that is changed and then checks to see if the T2 chip is assigned correctly, which in return will give Activation Server Error messages.
                    So in theory if you change the serial of an MDM device to new serial then you sign into your device with your iCloud after OS install and say you DFU reset it, that serial is now assigned to your iCloud with the T2 chip until you remove it.
                    Hope this helps
                    sigpic
                    • Brais
                      • Jun 2022
                      • España
                      #290
                      So,
                      Changing serial method will work on any T2 chip model, and sets it as a new device( any resets and updates will work as expected)?
                      And what happened if you register 2 different Iclouds with the same serial number?
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 674
                        Originally posted by Brais
                        So,
                        Original first iCloud will always kick back. No matter what you do, the first registered iCloud will always come back first. Meaning it needs to be removed. The second iCloud will not even exist, only when you use the device in of itself.
                        sigpic
                        • Brais
                          • Jun 2022
                          • España
                          #292
                          Many thanks for reply, seems logic, i will try and see what happened.
                          About T2 chip in a Macmini for exemple, is possible to remove Icloud with the serial method?
                          Thanks for help
                          • serkrn
                            • Jul 2022
                            Hello
                            I reset the Macbook air 3 2o 2o comes out of the ground (bridge6) and activated icloud.
                            If I flash the T2 chip with Unlock firmware with soldering, will it help to lower the bridge and bypass icloud activation?
                            • lamo
                              • Nov 2017
                              • 40
                              • Ukraine
                              #294
                              Originally posted by serkrn
                              Hello
                              no.
                              • serkrn
                                • Jul 2022
                                Originally posted by lamo
                                no.
                                what options are there?
                                • Brais
                                  • Jun 2022
                                  • España
                                  #296
                                  Hi, just someone who could ask this question:
                                  Its possible to unlock an Imac or a Macmini with T2 chip and an icloud activation lock with the serial hardware method?
                                  This item will remain as new, no locks , no icloud even with DFU mode resets?
                                  The only condition is the ibridge version as explained?
                                  Many thanks
                                  • kevingill
                                    • Jun 2013
                                    • 152
                                    • England
                                    #297
                                    This was discussed a while back and I actually bought one to try out.
                                    But sadly, there doesn't appear to be any purple mode software that works with Macs.
                                    • styleangel
                                      • Nov 2014
                                      • 9
                                      • Viet Nam
                                      #298
                                      warn someone buying a new mina tool. Apple did something to T2 and it doesn't work anymore
                                      • mich6el
                                        • Dec 2015
                                        • 18
                                        • Ukraine
                                        #299
                                        Hi! my t2 chip transplant experiment failed. I successfully soldered the t2 chip but my board most likely has an underestimated resistance PP1V1_S3. This piece of shit, that I bought on ebay turned on black screen, after 5 times gomg and apple, before replayse t2 chip, after i have cycle dinamic voltage on PP5V_G3S. FUCKING CALCULATOR! I think i have bad cpu on this board to. Who can measure resistanse of PP1V1_S3?
                                        • Timp74
                                          • Apr 2018
                                          • 36
                                          • Spain
                                          #300
                                          Originally posted by ugamazing
                                          Without being too informed on the current status/progress of a T2 bypass or unlock, can I ask a potentially-dumb question?
                                          Would it be possible to somehow identify the contact information (name/email) of the iCloud account owner of a particular board, and then simply attempt to contact them to have the lock removed? Of course many people wouldn't respond, and you'd still be stuck with a locked board, but I was curious if that information would somehow be stored on the board. I'd imagine that info is securely stored/encrypted in the SE, so probably impossible to get to, but was just curious.
                                          On a icloud locked a2179, I found the user's email in plain text using checkra1n and running the "strings" command on the NVRAM file in /var/private/db. I think that was the file and location.. Unsurprisingly the user didn't reply to my email or iMessage about unlocking..
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                            Common SPI bios chip programming Questions and Answers
                                            by SMDFlea
                                            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                            A: If you can`t read from it how do you expect to write to it ?.
                                            Q: Why is my bios chip unreadable ?.
                                            A: The programmer is faulty or has a worn or broken zif socket.
                                            The USB cable is frayed,connector pins worn or some other physical damage.
                                            Not enough amperage or voltage to power the programmer properly.
                                            Bad...
                                            09-02-2021, 04:40 PM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
