T2 Chip Programmer Tool
This topic is closed.
Re: T2 Chip Programmer Tool
I can give you my own one. I’ve got my A2141 locked. But actually I wanted to try to make it work by myself…)
Or you can sell me that ICs
P.S. I think that NANDs are not necessary to replace. But I still can be wrong.Last edited by LevanGood; 07-05-2022, 09:52 AM.Comment
but a2141 and a2179 have different flex of touch id. i want make fully worked board. but all my a2179 have dead cpu too. Sorry I have one chip set for experimentLast edited by mich6el; 07-05-2022, 01:32 PM.Comment
Ok maybe u have any logic board with unlocked T2 (FMM off)? Any? I mean MB Air 1932 or any? I think T2 replacement only can solve the problem and I just want to try it.
One guy sent me a video where one Chinese guy replaces T2 and make it work..Last edited by LevanGood; 07-05-2022, 02:33 PM.Comment
i have only one board witрout fmmComment
I've done quite a lot of searching to easily find out whether a MacBook is MDM locked, but failed.
What's the easiest way to find if it's MDM activated on a MacBook that's been reset, i.e. no operating system.
Is it the availability of the option in the Recovery Assistant -> Activate with MDM key?Comment
here
Use this command in terminal:
profiles status -type enrollment
Depending on your MDM enrollment status, you may see one of the following statuses shown below:
No MDM enrollment
computername:~ username$ profiles status -type enrollment
Enrolled via DEP: No
MDM enrollment: No
MDM enrolled, without user-approved MDM enable
MDM enrollment: Yes
MDM enrolled, with user-approved MDM enablee
MDM enrollment: Yes (User Approved)
DEP Enrolled
Enrolled via DEP: Yes
computername:~ username$Last edited by SMDFlea; 07-13-2022, 08:36 AM.Comment
it is not mdm locked if it is wiped and with activation lock. mdm gets installed during os installation.Comment
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by baletakHi,
had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
I have updated laptop model number.
1) I did not find the way to update laptop serial number - I have this one.
2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
Hope to find someone to help me with this as I am hitting dead end at the moment.
Many thanks
Miro-
Channel: BIOS Requests ONLY!
by SMDFleaAdding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
and once you do find them there`s a few crucial steps missing.
Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
After adding the chip save the xml file and copy it to the root directory of the...-
by SMDFleaCommon SPI bios chip programming Questions and Answers
Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
A: If you can`t read from it how do you expect to write to it ?.
Q: Why is my bios chip unreadable ?.
A: The programmer is faulty or has a worn or broken zif socket.
The USB cable is frayed,connector pins worn or some other physical damage.
Not enough amperage or voltage to power the programmer properly.
Bad...-
09-02-2021, 04:40 PM -
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... - Loading...
