T2 Chip Programmer Tool
This topic is closed.
  • newmac
    • Mar 2022
    • 7
    • Phillippines
    #201
    Re: T2 Chip Programmer Tool
    Originally posted by newmac
    Error i get is Unexpected device state 'DFU' expected 'Recovery' [com.apple.MobileDevice.Restore - 0xFAE (4014)]
    all of T2 standby power is present.
    the error im getting is
    The System cannot be restored on this device. Gave up waiting for device to transition from DFU state to DFU state. [com.apple.MobileDevice.MobileRestore
    0xFCA (4042)]
    • curiositymaster
      • Apr 2021
      • 45
      • Nigeria
      #202
      I guess you need to reprogram your ROM chip
      • mazoot
        iFixit
        • Jan 2019
        • 41
        • Moldova
        #203
        #newmac you need a working dump with your serial inside thats it.Give me your model and your serial number i will make it for you
        Kill the state in yourself and you will be free like a wind...
        • Terry011
          • Feb 2014
          • 7
          • England
          #204
          Hello, I brought a T203 programmer a little while ago, programmed the chip but did not realise at the time that the jaibreak was not compatible with Monterey.
          Does anyone know, if or when a new CheckM8/Mina Jailbreak for Monterey will be available? And if so will I have to pay for it?
          Thanks in advance
          • kjchatman
            • Dec 2012
            • 213
            • united states
            #205
            i purchased a random 2018 logic board. can someone tell me if my serial # is icloud locked?
            • kevingill
              • Jun 2013
              • 152
              • England
              #206
              Do you have the serial number for the board?
              You will only be able to activate if it's on the correct bridgeOS version.
              Might be worth pulling the ROM off the board and reading the contents to see both answers.
              • curiositymaster
                • Apr 2021
                • 45
                • Nigeria
                #207
                Thanks in advance
                Everyone's waiting for the next Checkrain update, which is indefinite at the moment.
                You can use Monterey on a jailbroken Mac if it was manually installed via bootable usb drive. The iboot version is the only thing that could prevent your jailbreak from working i.e if it's been updated above version 5.5.
                • kjchatman
                  • Dec 2012
                  • 213
                  • united states
                  #208
                  what information in the rom would indicate the bridgeOS version?
                  • kjchatman
                    • Dec 2012
                    • 213
                    • united states
                    #209
                    " a software update is required for this device" is the message that i get from configurator 2. Is that the ibridge 6 update? I've tried to use checkm8 activation service but it keeps losing connection.
                    • sinaps1
                      • May 2022
                      • 8
                      • Albania
                      #210
                      Originally posted by Stephen
                      Incorrect. MDM devices are the only devices you can change the serial number on T2 chips without issue. If it fails to activate on the server, the T2 chip itself was already activated and has the original iCloud and SN tied to the device.
                      Correct!! I suppose that this device was already activated. After I changed the Serial number to a compatible one as you suggested in the early posts went smooth to bypass the MDM, but can't reach the activation server of apple.. so my guess is that the link that it tries to reach is tied to the Serial number in the T2 chip and the serial number in the ROM. I suppose that I must w8 until the release of the jailbreak for Monterey.
                      • sinaps1
                        • May 2022
                        • 8
                        • Albania
                        #211
                        in the preview page a post from siddiq:
                        • kjchatman
                          • Dec 2012
                          • 213
                          • united states
                          #212
                          i have an a1990 that i purchased from a college surplus. It has activation lock but it boots to the login. Is there a way to get pass the login without knowing the password?
                          • kevingill
                            • Jun 2013
                            • 152
                            • England
                            #213
                            Reboot into recovery, go to terminal and type resetpassword
                            • kjchatman
                              • Dec 2012
                              • 213
                              • united states
                              #214
                              also the volume is encrypted
                              • kjchatman
                                • Dec 2012
                                • 213
                                • united states
                                #215
                                are there any paid services fo unlock a macbook if it has been updated to monterey?
                                • .::iRizwan::.
                                  Banned
                                  • Apr 2016
                                  • 63
                                  • Pakistan
                                  #216
                                  Depends if old BridgeOS or new.
                                  • kjchatman
                                    • Dec 2012
                                    • 213
                                    • united states
                                    #217
                                    how to can i tell what bridgeOS? i can remove the rom and read the contents. What would i be looking for?
                                    • jafasbay@gmail.com
                                      • May 2019
                                      • 19
                                      • mocambique
                                      #218
                                      Can you share file file for
                                      A2337
                                      • kevingill
                                        • Jun 2013
                                        • 152
                                        • England
                                        #219
                                        Probably worth a good read from the first post of this thread to the last.
                                        There's a photo of a Mac booting into recovery mode which will tell you whether the Mac is on the old bridgeOS version or newer.
                                        • anhbanxoi
                                          • Sep 2021
                                          • 178
                                          • VN
                                          #220
                                          Does anyone get the same error? Maybe Mina has fixed the tool.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • baletak
                                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                                            by baletak
                                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                                            I have updated laptop model number.
                                            1) I did not find the way to update laptop serial number - I have this one.
                                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                                            Many thanks
                                            Miro
                                            05-23-2025, 01:21 AM
                                            How to add chip support to NeoProgrammer software for the CH341A Programmer
                                            by SMDFlea
                                            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                            and once you do find them there`s a few crucial steps missing.
                                            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                            After adding the chip save the xml file and copy it to the root directory of the...
                                            05-26-2024, 07:15 AM
                                            Common SPI bios chip programming Questions and Answers
                                            by SMDFlea
                                            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                            A: If you can`t read from it how do you expect to write to it ?.
                                            Q: Why is my bios chip unreadable ?.
                                            A: The programmer is faulty or has a worn or broken zif socket.
                                            The USB cable is frayed,connector pins worn or some other physical damage.
                                            Not enough amperage or voltage to power the programmer properly.
                                            Bad...
                                            09-02-2021, 04:40 PM
                                          • BMCappelletti
                                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                                            by BMCappelletti
                                            Long story short:
                                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                            - gave the computer to his son a couple years later
                                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                            (seems like the story was not that short)
                                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                            01-08-2025, 07:27 PM
