Model Getac:V110
S/N RH503V2675
V110g3
Getac V110 Bios Needed.
Please help me find out the BIOS password
S/N RH503V2675
Model: V110g3Attached FilesLast edited by Gerasim_2; 04-28-2025, 03:18 AM.Leave a comment:
tryAttached FilesLeave a comment:
post S/N, full name and model, motherboard model, etc.
Don't post pictures unless asked..
read the forum rules..
https://www.badcaps.net/forum/troubl...ore-postingLeave a comment:
Hello everyone, I need help, Getac v110 g4 at the beginning there was Bios r1.05 accidentally updated to R1.22 the backlight on the laptop disappeared, I can't return it back. I bought a donor with R1.05 changed the chip but the laptop does not turn on, thanks in advance for your helpLeave a comment:
Hello all, it there anyone that has the V110G3 bios version INSYDE R1.14.070520 ?
I've tryed to search inside the published files but only found:
R1.03.010600 v110_g3
R1.03.251518 getac_v110_g3_bios.bin
R1.05.070520 W25Q128B.BIN
R1.06.021519 w25q128f_orig_loked.bin
R1.07.070520 W25Q128FV@SOIC8.BIN
R1.25.070520 RH503V1992.bin
R1.25.070520 getacv110.rom
R1.25.070520 v110_bios.bin
R1.25.070520 v110g3_RK303V0299.bin
I'm trying to reproduce a very specific and unusual issue, and I guess that the bios may do the trick.
I cannot upgrade the end user devices, and I currently have a more recent version on mine.
Thanks in advance
\JekyLeave a comment:
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
I re-read the bios by soldering it to the programmerAttached FilesLeave a comment:
here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHowAttached FilesLeave a comment:
here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHowLeave a comment:
I read the flash drive again, but when checking it, it gives an error (when comparing the chip, it does not match the buffer)Attached FilesLeave a comment:
Good afternoon, I managed to read the bios, help me find out the password.Attached FilesLeave a comment:
by GrafZahlHi!
I am in desperate need for a Bios dump from an Getac V110 G5.
It needs to be from a stock V110 G5, not a Bosch DCU220 (that also is labeld V110 on the bottom).
If it is password locked, that is no problem.
Thank you in advance!...-
Channel: BIOS Requests ONLY!
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
- Loading...
