Lenovo ThinkPad E15 Gen2 NM-C771 need dump
  • no1here4u
    • Jul 2023
    • Puente
    #41
    Hi! Could anyone help me with a bricked Thinkpad E15 Gen2 AMD? (Ryzen 5 4500u)
    The attached file has been uploaded to this post earlier, and I guess it should work with my laptop model.
    The serial number is PF2C8AAJ.
    Can't get the bios dump because the previous owner has already tried to write on the Bios without backing it up first... I tried using the attached file with no luck. Laptop starts but I get no picture.
    Thanks in advance!
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      #42
      Serial Number:- PF2C8AAJ
      Try a new one
      Extracted from Lenovo support
        SMDFlea commented
        Editing a comment
        SN is in the EC as far as i know,only win key in backup, at the end of EVSA region. Copy the win key block after 07 EC 7B 1A 29 A1 C1 F1 91 FD 48 86 6E 3E CE CB .Copy the key including the SDK0J40697 WIN . .You can copy the whole EVSA region if you wanted to 5E0000 ,length 10000
    • no1here4u
      • Jul 2023
      • Puente
      #43
      Try a new one
      Hi qayyum786, thanks for your reply!
      I'm sorry, I made a mistake with the Serial Number... that was from a working laptop.
      The correct SN is PF1B2E1L
      Could you help me with this one?
      • qayyum786
        qayyum786 commented
        Editing a comment
        no issue. I check both with serial number and both are same
        feel free to flash given bios and copy win key from offset given by smdflea
    • Dan20701
      • Sep 2020
      • 204
      #44
      Hello all, Is this only possible with vertyanov programmer ?. is there no way to do it with RT809H and the keyboard adapter ?
      Thanks for any advice.
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1356
        • France
        #45
        https://www.badcaps.net/forum/troubl...ss#post3237235
        • vladfxnet
          • Jul 2022
          • 5
          • Ukrain
          #46
          Hello guys and help out!! Lenovo thinkpad e15 gen 2 (BIOS CHIP gigadevice 25q80csig) when press the power button 3 times it blinks quickly and then constantly blinks for a long time. I think it's a firmware issue. I read the BIOS and was surprised by the file with a size of 1Mb. Here the firmware is 16Mb. When I try to flash it, it says there is not enough space (as i see flash has 10Mb). matherboard GE4B0/GE5B0 NM-D011. CH341A programmer - Neoprogrammer. All fotos can attach if necessary/
          • vladfxnet
            • Jul 2022
            • 5
            • Ukrain
            #47
            BIOS
            • Markus1741
              • Sep 2020
              • 953
              • N/A
              #48
              Hello, why does everyone always want to flash the +3.3V_TBTA_FLASH USB-C PD controller chip, I don't understand it.
              The chip is responsible for USB-C and has nothing to do with BIOS, so don't bother with it.
              On this model, the BIOS is 33.6 MB (33,554,432 bytes)
              • vladfxnet
                • Jul 2022
                • 5
                • Ukrain
                #49
                Hello, thank you for your answer. I'm not an expert in this area, but... We have a war going on and i can't go out into the street to send it in for repairs, so i have to try it myself. Tell me what this BIOS looks like, and could there be a problem with it? When the board is connected there is still something whistling, but not always.
                On this site I downloaded several BIOS files but they are all approximately 16MB
                  • 22001
                  Please post the laptop serial number. I hope you made a backup of that 1MB chip,as you`ll have to flash it back.As already said,its not the bios. The bios chip will most likely have 25Q256 etched on it
                  • Markus1741
                    • Sep 2020
                    • 953
                    • N/A
                    #51
                    You're right, according to the schematic, your BIOS is 16.8 MB (16,777,216 bytes) and should be found under the name UC4 (board number space).
                    I think there are two options.
                    1. Your BIOS is defective. Hard to say without BIOS.
                    2. Or a hardware defect. It can also be.
                    You should just upload your original BIOS.​
                    • ChrsOvkll
                      • Jun 2024
                      • 7
                      Hi, sorry for asking here, I am thinking this is going to be bad news for me, but, what if I Erased/Flashed the PD controller chip, thinking it was bios chip (winbond 25q80dvsig) and the "backup" I have is mostly F's and zeroes and a few hex characters here and there, and when I flash it back (The original file) the motherboard is still dead? is it gone? Is there a way to find or fix the file to flash it back if I read the bios main chip and try to rebuild it from the hex characters? thanks
                      • Markus1741
                        • Sep 2020
                        • 953
                        • N/A
                        #53
                        • vladfxnet
                          • Jul 2022
                          • 5
                          • Ukrain
                          #54
                          Hello, I think I found it. Photo below. But the chip is strange, its legs are very short and you will probably have to solder it. Because I used a clothespin.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12354
                            #55
                            Click image for larger version  Name:	dataurl678297.png Views:	0 Size:	359 Bytes ID:	3294571
                            https://shopee.vn/Tianye-Sop8-W-son-...7-e86cbbfcd89d
                            ​https://www.badcaps.net/donate
                            • redoxy
                              • Sep 2018
                              • 100
                              Can someone please help remove Absolute Persistence?
                              Machine Type: 20T8-005CUS
                              Serial: PF-39CYL3
                              Motherboard: GE420/GE520 NM-C771
                              Laptop: ThinkPad E15 Gen 2
                              Thanks, in Advance
                              • volinakis
                                • Jan 2021
                                • 2874
                                • N/A
                                #57
                                Serial: PF-39CYL3
                                Thanks, in Advance
                                try. after write new bios go in bios setup - security - absolute and permanently disable
                                • redoxy
                                  • Sep 2018
                                  • 100
                                  Thanks, volinakis
                                  It worked.
                                  I appreciate it.
                                  Cheers!
                                  • volinakis
                                    • Jan 2021
                                    • 2874
                                    • N/A
                                    #59
                                    Thanks, volinakis
                                    It worked.
                                    I appreciate it.
                                    Cheers!
                                    you are welcome
                                    • enversefa
                                      • Oct 2016
                                      • 25
                                      • istanbul
                                      #60
                                      I need to unlock the bios password
                                      Board Number: GE420/GE520 NM-C771 Rev : 1.0
                                      Serial Number: PF-2X9Y5C
                                      Type Number: 20T8-01RTX
                                        Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) X Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + USB-C Dock Gen2 (40AS0090AU) boardview and X1 Yoga + USB-C Dock Gen2 (40AS0090AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                        09-06-2024, 09:45 AM
                                        09-06-2024, 09:40 AM
                                      • Grafnus
                                        Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                                        by Grafnus
                                        Hey there,
                                        first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                                        So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                                        Specs:
                                        • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                                        • CPU, GPU, RAM work fine (not involved in the Problem)
                                        So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                                        Now I noticed...
                                        08-06-2025, 11:54 AM
