Sony MBX-268 ME Version unknown, please help
  • ruletero
    • Nov 2018
    • 183
    • Mexico
    Hi everyone
    Problem: Laptop turns off at 30 minutes. in bios setup shows "ME version Unknown".
    I have tried several bios files without sucess, same problem and I don't know how to fix the error. The laptop doesn't have discrete graphics.
    Could someone help me to resolv the problem? Or what thing can I do to resolv it? I don't have the original bios, I attach a working bios that shows the error.
    Your help is very appreciated.
  • peste
    • 13853
    • ROMANIA
    Re: Sony MBX-268 ME Version unknown, please help
    Originally posted by ruletero
    Hi everyone
    post the full name and model of the laptop and the model of the motherboard.
    • ruletero
      • Nov 2018
      • 183
      • Mexico
      Sony SVE14125CLW
      MB: DA0HK6MB6G0 Rev G.
        • 22197
        Sony SVE14125CLW
        Have you checked that the CPU is compatible with the chipset.The model has a i5-3210M 3rd gen
        • ruletero
          • Nov 2018
          • 183
          • Mexico
          It has other model too: SVE141C11U
          The laptop has an Core i5-2450M processor, I received the mother with this processor.
          Where can I check its compatibility, please
            • 22197
            try this bios
            Try the ME drivers too if you have a yellow triangle mark in device manager,these are for win 8 - https://www.sony-latin.com/en/electr...loads/W0007988
            • ruletero
              • Nov 2018
              • 183
              • Mexico
              Thank you SMDFLEA but not luck, it turn off at 30 minutes.
              I don't have yellow warning, only I installed the Sony Parser Driver.
              I downloaded two bin files and cleaned ME Region with yoyour guide but in the bios screen still shows "ME Region Unknown".
                • 22197
                try another bios - https://www.badcaps.net/forum/showthread.php?t=69312
                • ruletero
                  • Nov 2018
                  • 183
                  • Mexico
                  Originally posted by SMDFlea
                  Yes, I tried with this bios file, no success.
                  I think something was changed in this laptop, processor, motherboard, assembly, I don't know
                  • sijones99
                    Sony Vaio SVF1521K4E 'ME version unknown'
                    by sijones99
                    Hi Everyone, please can I share my situation and see if anyone has any ideas? I'm trying to help my brother out, but am at the outer limits of my knowledge. I'd like to do my best before this laptop gets thrown away - it's quite a good spec and I think it'd be a shame to trash it without trying. Also, I'd like to understand the problem for my own experience.
                    I've been searching online, but am not really any the wiser.
                    The laptop
                    • Sony Vaio SVF1521K4E
                    • Intel Core i5 - 3337U, 1.80GHz x 2
                    • Onboard graphics
                    Background / symptoms
                    This is my brother's...
                    01-22-2022, 09:44 AM
                  • TheUser
                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                    by TheUser
                    Hello to everyone ,
                    This is my first post here, and i would like to share with you a small story in case you can help me.
                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                    02-10-2024, 02:07 PM
                  • guipmw
                    Sony mbx-216 DA0GD3MBCD0 HM55 - ME version unknown
                    by guipmw
                    Hello
                    Problem: Laptop shuts down after 30 minutes, on the bios setup the ME Version is displayed as "unknown"
                    I tried to clean the ME region (https://www.badcaps.net/forum/showthread.php?t=88533) no success
                    I tried other bios files, EC bios files, CPUs, can you beautiful peoples bless me with thy wisdom?...
                    12-14-2020, 08:36 PM
                  • microso
                    All in one Sony Vaio VPCL22Z1E 3D version no video on main display
                    by microso
                    I bought an all in one Sony Vaio VPCL22Z1E 3D version which does not show anything on the display, instead it works ok on the hdmi output (video and sound).
                    I tested with a flashlight and it seems that it does not display the image without backlight.
                    It doesn't make any sound in the built-in speakers and the headphone output has a very weak level.
                    As an observation, I use a 19.5V power supply with 120W and in the specifications the original one would have 180W.
                    Could this be the reason why it doesn't work properly?
                    Mainboard is V021_MP_3D_1.1 1P-0115J00-8011...
                    12-18-2023, 08:29 AM
                  • sikocan
                    Lenovo X1 Carbon 9th Gen Black Screen
                    by sikocan
                    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                    SN: PF3G1REP
                    MODEL: 20KW-00J1AU
                    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                    06-24-2025, 09:01 PM
