ThinkPad L450 _ NM-A351 BIOS Password Unlock
Become a Badcaps supporter
Thanks to all supporters.β
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: ThinkPad L450 _ NM-A351 BIOS Password Unlock
must be dual bios chips, end of file is all FF`s and ME firmware is corporate 5MBComment
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
AUTOPATCHER is not working on this Lenovo laptop!
here is a solution to unlock L450 BIOS.
For safety reasons make dump backup and take care during security chip shortening. Make also picture on bios SERIAL number and so on (just push enter when as for password to go inside locked BIOS).
1. Prepare something to short circuit SDA and SCL line of security chip.
2. Remove hard drive.
3. Switch on laptop and immediatelly shortcircut this 2 lines, as on picture.
4. When laptop will show error with laptop serial and so on take press F1 to enter to the bios. Take out shortening tool. Don't worry if you won't see serial number and so on for now.
5. Go to supervisor password and just press enter two times to save empty password.
6. Go to last page and click SAVE & EXIT.
7. Switch off laptop and then switch back on, push enter and then F1 to go to BIOS and VOILA. Password has been deleted. Laptop serial data shall be returned.
Say thank you if this helpedLast edited by rbvndonh; 05-09-2023, 01:44 PM.Comment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by MaxonDomkratHi everyone.
I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES β Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...-
by 1g0rHello everyone,
First, the data in brief:
Manufacturer: Lenovo
Model: ThinkPad L15 G3 21C3-0016GE
motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
IC Bios 1: MX77L25650F
IC Bios 2: MX25L25673G
EC Chip: NPCX997KAABX
So far I've been a silent reader, but now I need your help
I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge -
by macabookHello everyone,
Iβm currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iβm at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereβs a full breakdown:
π§© Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM - Loading...
