Asus k75vj Bios
  • WhyINeedAccount123
    • Feb 2021
    • 19
    • Poland
    Asus k75vj Bios
    Hi BadCaps Friends, i need bios for asus k75vj, can someone help me?
    Mobo la-8222p rev 2.0.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Asus k75vj Bios
    post the backup of the bios
    • alihomee
      • Dec 2012
      • 1599
      • malaysia
      Re: Asus k75vj Bios
      try and post results
        • Feb 2021
        • 19
        • Poland
        Re: Asus k75vj Bios
        No results, still black screen.
        • flayer23
          • Apr 2012
          • 13
          • france
          Re: Asus k75vj Bios
          file tested ok thank 's
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
