Asus tp501ub rev 2.0 bios please
  • rager007
    • Feb 2016
    • 106
    • Usa
    tp501ub rev 2.0 bios dump
    Thank you please bios.
  • peste
    • Dec 2016
    • 12643
    • ROMANIA
    Re: Asus tp501ub rev 2.0 bios please
    post the backup of the bios
    • rager007
      • Feb 2016
      • 106
      • Usa
      backup
      • peste
        • Dec 2016
        • 12643
        • ROMANIA
        backup
        try..
        • rager007
          • Feb 2016
          • 106
          • Usa
          0.80 amper cpu and gpu hot No display no ext hdmi thx peste
          • florenz
            • Apr 2018
            • 43
            • Cameroon
            Hello Guys
            i'm from central Africa, i have an Asus TP501UB rev2.0 ; it start well , fan spin , cpu get hot but nothing show on screen.
            i think my bios.bin is corrupt...
            can someone help me ?
            in attachments my bios.bin backup
            • hoaca388
              Badcaps
              • Jan 2022
              • 11640
              Originally posted by florenz
              Hello Guys
              Asus tp501ub
              • florenz
                • Apr 2018
                • 43
                • Cameroon
                Originally posted by hoaca388
                Asus tp501ub
                THX YOU SO MUCH .... IT WORKS SMOOTHLY
                • zatara10
                  • Nov 2016
                  • 25
                  • sweden
                  help
                  fan work , cpu and gpu get hot but nothing show on screen.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11640
                    Hi !
                    • zatara10
                      • Nov 2016
                      • 25
                      • sweden
                      Hi !
                      Thanks,
                      The problem was in the internal ram, there was no contact, it was fixed when heated.
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • Anchar777
                        ASUS P1412CE need BIOS DUMP
                        by Anchar777
                        Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                        06-26-2025, 03:39 AM
                      • kcp0085
                        Request BIOS dump for ASUS FA617NS-A16.R77600
                        by kcp0085
                        Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                        I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                        Specs:
                        - ASUS TUF FA617NS-A16
                        - CPU: AMD Ryzen 7
                        - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                        If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                        Thanks in advance!​
                        05-02-2025, 12:52 AM
