Asus tp501ub rev 2.0 bios please
  • rager007
    • Feb 2016
    • 106
    • Usa
    tp501ub rev 2.0 bios dump
    Thank you please bios.
  • peste
    • 13599
    • ROMANIA
    Re: Asus tp501ub rev 2.0 bios please
    post the backup of the bios
    • rager007
      • Feb 2016
      • 106
      • Usa
      backup
      • peste
        • 13599
        • ROMANIA
        backup
        try..
        • rager007
          • Feb 2016
          • 106
          • Usa
          0.80 amper cpu and gpu hot No display no ext hdmi thx peste
          • florenz
            • Apr 2018
            • 48
            • Cameroon
            Hello Guys
            i'm from central Africa, i have an Asus TP501UB rev2.0 ; it start well , fan spin , cpu get hot but nothing show on screen.
            i think my bios.bin is corrupt...
            can someone help me ?
            in attachments my bios.bin backup
            • hoaca388
              Badcaps
              • Jan 2022
              • 12330
              Originally posted by florenz
              Hello Guys
              Asus tp501ub
              • florenz
                • Apr 2018
                • 48
                • Cameroon
                Originally posted by hoaca388
                Asus tp501ub
                THX YOU SO MUCH .... IT WORKS SMOOTHLY
                • zatara10
                  • Nov 2016
                  • 25
                  • sweden
                  help
                  fan work , cpu and gpu get hot but nothing show on screen.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12330
                    Hi !
                    • zatara10
                      • Nov 2016
                      • 25
                      • sweden
                      Hi !
                      Thanks,
                      The problem was in the internal ram, there was no contact, it was fixed when heated.
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • ArkzG
                        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                        by ArkzG
                        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                        What I currently have available:
                        - Model: FA506NF (2021)
                        - BIOS chip: GD25LQ16 (16Mbit/2MB)
                        - Tools: CH341A programmer ready to use
                        Does anyone have either a clean 2MB .bin dump of this model,...
                        09-26-2025, 09:34 PM
                      • kodox
                        Asus ExpertBook B1400CB Bios Dump Needed
                        by kodox
                        need original bios dump, original bios has flashed by other technician before me.
                        attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                        unit info:
                        Model: Asus ExpertBook B1400CBA-0711A1235U
                        S/N: R6NXNZ006657238
                        CN: 7F6F
                        Mainboard Code: B1500CBA R2.1...
                        08-16-2025, 12:20 PM
