ASUS TP412UA BIOS Request / Help with UEFI Tool
+ More Options
Posts
  • fabian14
    • Jan 2021
    • 26
    • Colombia
    Re: ASUS TP412UA GPU or CPU not turning ON
    Originally posted by sikocan
    Bios flashing fixed. Found one on the net, it worked but 30 sec delay and didn't detect ram. I have fixed those in the attached cleaned me region for others to use.
    Works!! Thanks
    • apachioara
      • May 2022
      • Romania
      Works great! God bless you! Thanks!
      • djharold
        • Aug 2015
        • 241
        • COLOMBIA
        Re: ASUS TP412UA BIOS Request / Help with UEFI Tool
        thanks work for me
        • reformatt
          • Feb 2020
          • 1408
          Has anyone got a dump of the embedded controller for this model? Just had one come in with a shorted EC, the code isn't in the main BIOS.
            • 20826
            240000 - 25FFFF .Found using 2 searches, 02 00 70 02 00 11 and J7IFT .Open the bios with UEFITool ,its in the padding area, with the DMI in the same padding , (CNFG)
            • reformatt
              • Feb 2020
              • 1408
              Yep, was trying to work it out, and realised it was in there but where....it really is a black art!
              Anyway, no schematic on this one. Thermal camera showed the RT6228A (K6=) getting hot, along with the EC. Still 3 ohms on the LDO after I took the EC and that IC off, and this is also continuous to another coil on the other side of the board near the DC jack. So to have a complete short from a LDO to another supply means some dead silicon, and likely hit by lightning or something. Another board bites the dust.
              • dr.thodt
                • Apr 2016
                • 80
                • Netherlands
                #27
                Could somebody fix this bios for me? The laptop does run with a lend Bios downloaded from this site, but I want its original bios on it.
                From the sticker:
                TP412UA-EC098T
                SN: K1N0JX00Z194043
                CN: BBW7
                MFD: 2019-01
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11715
                  #28
                  From the sticker:
                  TP412UA-EC098T
                  SN: K1N0JX00Z194043
                  CN: BBW7
                  MFD: 2019-01
                  TP412UA
                  Mọi khoαΊ£n quyΓͺn gΓ³p cho badcaps đều được hoan nghΓͺnh, hΓ£y nhαΊ₯p vΓ o liΓͺn kαΊΏt nΓ y để quyΓͺn gΓ³p. CαΊ£m Ζ‘n tαΊ₯t cαΊ£ nhα»―ng người α»§ng hα»™----------------------------------------------------------------------------------------------------------------------------------------------------------------
                  • dr.thodt
                    • Apr 2016
                    • 80
                    • Netherlands
                    #29
                    Originally posted by hoaca388
                    TP412UA
                    Unfortunately this bios does not work. The bios that worked is from post 10. Using uefi tool I can only find the start of the ME region but not the end.
                    • dr.thodt
                      • Apr 2016
                      • 80
                      • Netherlands
                      #30
                      I got it working myself by replacing my bios region with the one from post 10 using uefi tool.
                      • M4n0l0307
                        • Nov 2020
                        • 165
                        • Colombia
                        #31
                        Working; Thanks Friend !
                        • coelectron
                          • Mar 2014
                          • 58
                          • Argentina
                          #32
                          Hello friends! can someone help me with this bios ( powered, but not showing video internal/external)
                          backup attached
                          ASUS TP412UA Rev 3.0
                          • peste
                            • Dec 2016
                            • 12755
                            • ROMANIA
                            #33
                            backup attached
                            read the rules..https://www.badcaps.net/forum/troubl...before-posting
                            post the S/N, the motherboard model, etc.
                            • coelectron
                              • Mar 2014
                              • 58
                              • Argentina
                              #34
                              Sorry
                              Mother model TP412UA Rev 3.0
                              notebook Model: Asus TP412UA-DB71T
                              Serial number J7N0JX00308629B
                              attached backup again
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11715
                                #35
                                Sorry
                                Asus TP412UA
                                • coelectron
                                  • Mar 2014
                                  • 58
                                  • Argentina
                                  #36
                                  Asus TP412UA
                                  Thhanks friend, but no working. ☹
                                  with this file when pressed power booton, only blink power led (once)
                                  • nexus96
                                    • Apr 2025
                                    • Colombia
                                    #37
                                    TP412UA
                                    saludos, sabes que programadora podria usar para este chip, tengo ch341a pero no me lo detecta, siempre ic no responding.
                                      • 20826
                                      Post in ENGLISH !
                                      • tokesszabi
                                        • Mar 2015
                                        • 12
                                        • Romania
                                        #39
                                        I have one TP412UA with EC shorted. There is a fw for them? Or they don`t need programmed ?
                                        • tokesszabi
                                          • Mar 2015
                                          • 12
                                          • Romania
                                          #40
                                          I have one TP412UA with shorted IT8987E.
                                          So I have changed it, nothing shored, but no power. Every voltage present.
                                          It has a 128Kb memory but I do not have the file.
                                          • peste
                                            peste commented
                                            Editing a comment
                                            post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
                                          ASUS VivoBook TP412UA-EC056T Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook TP412UA-EC056T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP412UA-EC056T boardview and TP412UA-EC056T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 12:36 PM
                                          ASUS VivoBook TP412UA-EC193T Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook TP412UA-EC193T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP412UA-EC193T boardview and TP412UA-EC193T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 11:35 AM
