abq52 la-c811p
  • pippo_one
    • Aug 2010
    • 127
    • Vicenza
    abq52 la-c811p
    Hi everyone
    I have a hp250 g4 with mainb la-c811p i wanted to replace my hdd with an ssd because it is too slow, but once the disk is replaced, the notebook turns on the video lights up but does not send any signal, the cursor flashes up to the left, if I press "esc / f1 / f2 / f9" at the bottom left the title of the function appears but I do not access the bios
    Pls can anyone help me? is it possible that the bios is corrupt?
    Thank you
  • pippo_one
    • Aug 2010
    • 127
    • Vicenza
    Re: abq52 la-c811p
    Hi , Can anyone help me ?
    • piernov
      • Jan 2016
      • 4439
      • France
      Re: abq52 la-c811p
      Of course you tried putting back the original drive?
      • pippo_one
        • Aug 2010
        • 127
        • Vicenza
        Re: abq52 la-c811p
        HI, Yes I have found to put the original hdd back but nothing the problem persists
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          Re: abq52 la-c811p
          check the HDD socket, check the contact between the HDD socket and the motherboard..if they are ok post the backup copy of the bios ..
          • pippo_one
            • Aug 2010
            • 127
            • Vicenza
            Re: abq52 la-c811p
            i checked attack hdd it looks good to me, just a question as I am a beginner, I unsoldered the cmos and now I am going with the epz2019 to read the bios, in your opinion it is better that you use a 1.8volt adapter?
            thank you
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              Re: abq52 la-c811p
              thank you
              I don't know what bios chip you have on the motherboard and I didn't use this programmer, but, measure the voltage at pin 8 of the bios chip and use the 1.8v adapter only if you find this voltage at pin 8, to read and write the bios chip, I think the programmer should tell you if you need to use the adapter ...
              • pippo_one
                • Aug 2010
                • 127
                • Vicenza
                Re: abq52 la-c811p
                Hi, here is the backup of the bios detected
                thank you
                • peste
                  • Dec 2016
                  • 13924
                  • ROMANIA
                  Re: abq52 la-c811p
                  thank you
                  try..
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
                  • Pinky Deepak
                    Vizio M60-C3 Left Edge problem
                    by Pinky Deepak
                    I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                    Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                    09-27-2024, 05:11 PM
                  • armoured_smiler
                    Panasonic Tx-40cx400b top left half screen not displaying correct
                    by armoured_smiler
                    Trying to work out if this is TFT problem or TCon issue.
                    The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                    Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                    04-08-2024, 03:40 PM
                  • Sik_6ty_Sixx
                    HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                    by Sik_6ty_Sixx
                    So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                    02-18-2025, 05:06 AM
                  • artasdmc
                    MSI 3070 Ti Suprim short on 12V left 8 pin, and short on 5V.
                    by artasdmc
                    Hi, I've got a 3070 ti that used to work for a limited time, my friend bought it expecting it to be a thermal/psu issue, but alas it is not. It died completely and it shorted out two rails on its way out. It blew a fuse on the left connector, but for testing purposes I've just used a 20a wire fuse to connect it back.
                    I think the core should be fine as PEX coil is reading about 9 ohms.
                    These are the two coils that are showing a short. I do have a thermal camera, so I injected 1v/0.9a at the 5V coil and the orange dot is where it heats up (it's a capacitor). When I inject the...
                    11-17-2025, 06:09 AM
