Hi
can somebody help to remove a admin password from bios Latitude 5520
ST: 90G5SG3-8FC8
thanks in advance
Dell Precision 5520 bios password
Finally I got it working using the code generated by bios-pw
Problem was I am using an azerty keyboard and for some reason I have to enter the code like it's a qwerty keyboard...Leave a comment:
Need the code to unlock my Dell Precision 5520 bios please
Service tag: HD291N2-E7A8
ThanksLeave a comment:
❤️YOU MUST:
❤️Provide the full machine model number, serial number (or Service tag, SNID)❤️
❤️Motherboard part Number and revision (except QR codes)❤️
❤️Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms❤️
https://www.badcaps.net/forum/showthread.php?t=103570Leave a comment:
Read the rules before posting
https://www.badcaps.net/forum/troubl...before-posting -
Hi, with this serial bios-pw gives me a wrong pass
3M47GG3-8FC8Leave a comment:
Re: Dell Precision 5520 bios password
When I enter the system number in either https://bios-pw.org/ or https://beta.bios-pw.org/ the I don't get "Dell from serial number", just "Dell HDD Serial Number (old)".
Can you please help me with this?
System Number: 630ZV93-8FC8
Need help:
HVFJMH2-6FF1
the bios pw sites say forbidden, or I don't know how to use them. Can someone help with possible keys?Leave a comment:
Sorry, I forgot to specify that a qwerty keyboard is connected to the USB port.
I found this password: Q0H3ZtCB6tHZKIWW
No error: 0 = zero
and I've respected upper and lower case.Leave a comment:
The password must be typed with US layout keyboard, try with the external USB keyboard with US layout. After entering the password confirm with Ctrl + Enter Enter.
.Leave a comment:
I have forgot the admin password on my Precision 5520, tried password generator using 6ff1 and bf97 but no one work.
Usb keyboard plugged, tried in upper and lower case same issue.
Could you help me ?
HY22RQ2-6FF1
Thank you.Leave a comment:
You may contact an official Dell representative office for further resolution of the matter by presenting proof of purchase/ownership.
3. Password removal by laptop brand
DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices. The information given here is for personal use only, ie. you accidentally set a password on your own machine, you forgot the password you set a long time ago or you mistyped the password when setting it and cannot get in again.
Note that a device bought locked might also have been stolen if the previous owner cannot give the correct password. This is especially common with business-grade equipment (Lenovo ThinkPad…) that employees sneak out or do not return.Leave a comment:
Is it possible to change the service tag? I bought a Precision 5520 which is tied to another corporation, and you can't log in to yours.
DSTCD does not changeLast edited by Vesko356; 05-03-2023, 02:03 AM. Reason: The request doesn't meet the rules. Attached archive removed.Leave a comment:
.Leave a comment:
Channel: BIOS Requests ONLY!
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
by markenero3Good Day Everyone please help! I have Dell precision 3480 13th gen with Bios password and absolute enable. I already tried 8FC8 Patcher it works but the absolute still cannot be disabled
Here is my Orig bios file with Bios password and Absolute Enabled
Board: IDB40 LA-M402P
Service Tag : HFZW724
Thank you So much in advance....-
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
by cozilyI bought a DELL Precision 3660 Tower Workstation from a second-hand seller. After bringing it home, I found out it was actually a testing unit. The BIOS cannot be upgraded (only the ME and PD2 sections are upgradable), and there are test messages displayed during boot, which really affects the user experience.
Upon inspecting the motherboard, I noticed that the BIOS is composed of two chips: one 8-pin 16MB chip and one 16-pin 32MB chip.
I acquired two new chips from another source containing the official BIOS version, but after installing them, I found that none of the...-
- Loading...
